I have a question about the panopticon screen configuration and input settings.
First, I attached a short video, so please check it out.
The versions I am currently using are as follows.
AI Hub (+ panopticon) = 2024.1, AI Studio = 2025.0.1
First, I created a model with test data that predicts 2 real outputs and 1 category output with 4 real inputs and 1 category input using AI studio (A~D, F > P1~P3)
After that, I created an endpoint with AI Hub, and successfully created a simple dashboard that predicts outputs when inputs are entered in real time by parameterizing the input data in panopticon.
I have three questions here.
1.
When inputting with the action slider, I formatted it so that it displays up to 1 decimal place, but the action text box in the same dashboard displays more than 10 decimal places.
Also, when using the slider, the output items often disappear.
I don't know if the part where the linked action text box displays a lot of decimal places is the cause of this problem, but is there a way to fix it?
This part is shown in the 'q1' video.
2.
Using the action button, I created a button that inputs multiple input sets at once.
When I set A=3, b=high, C=6 as constants and clicked the action button, I confirmed that the input variables were changed normally.
However, at this time, all the output label screens disappeared.
This part is shown in the 'q2' video.
3.
I right-clicked the workbook icon on the workbook workspace screen, clicked Share, and followed the link that appeared, but the address changed to 'http://panopticon-vizapp:8080/panopticon/workbook' and a message saying that the connection could not be made appeared.
I installed it by changing the ai hub port to 5440, but did this cause the problem?
This part is shown in the 'q3' video.
Lastly, I attached the database and dashboard screen settings used in Panopticon to the 'set' video, so please check it.
