edem —server "servername" to select a specific server. For 'servername' you can put the IP or name of the server. For the 'edem' command you will likely want to specify the full path to the 2025 install EDEM/bin/edem folder.
HI,
The student edition license will only work on one computer, it is intended for use in a student`s personal PC for learning purposes only.
Since your university has purchased licenses i.e. Altair units managed in Altair one, you can connect to that as per
Contact your IT admin about connecting to your university license server in the university premises if any.
