It is possible that the CAD import failed mid-import and left a process running which then blocks the next import.
To resolve I would first recommend restarting the PC to see if this resolves the issue.
You mentioned changing the Geometry Import Temporary FIle Location? Could you confirm you set this to a location you have read-write permissions. I would use these settings, with 'Alternative Windows import method de-selected"
Hi,
