Error with MAT9OR
Hello Team,
I got this below error while doing optimization, and I cannot get the model to run successfully. If I use PARAM,MATCHECK, No, then I would probably get wrong results. what should I do? I changed my design variables bounds, but that still did no do it.
A fatal error has occurred during computations:
*** ERROR # 1551 ***
for material id = 21 referenced from property id = 21.
Material coefficients Gij on MAT9 card produce material matrix with negative
eigenvalues. This violates material stability conditions.
Eigenvalues of G: 5.811209e+04 -4.221653e+05 1.943692e+04
5.542000e+04 2.917000e+04 3.024000e+04
*** PROGRAM STOPPED: FATAL ERROR(s) ENCOUNTERED
Great that you sorted it out!
I guess it could be hard to cover all combinations of instability, that's why the generic text in the .out file.
I normally do min/max overchecks before I do optimisation, then one know the "potential" of the problem/design
Anyway, good luck with your optimisation!
/johan
There are a few stability checks needed for the material
Hi Numair!
I had the same error as yours. I changed my lower E value and this kind of sorted out. However, have you got any clue about how do OptiStruct calculate matrix G? I would like to calculate the eigenvalues of that matrix by myself. In that way we could be closer to a proper solution rather than changing values randomly.
Thank you!
Hi Numair
So by alternating bounds do you mean that you have design variables for material coefficients Gij?
/Johan
