Hello Team,
I got this below error while doing optimization, and I cannot get the model to run successfully. If I use PARAM,MATCHECK, No, then I would probably get wrong results. what should I do? I changed my design variables bounds, but that still did no do it.
A fatal error has occurred during computations:
*** ERROR # 1551 ***
for material id = 21 referenced from property id = 21.
Material coefficients Gij on MAT9 card produce material matrix with negative
eigenvalues. This violates material stability conditions.
Eigenvalues of G: 5.811209e+04 -4.221653e+05 1.943692e+04
5.542000e+04 2.917000e+04 3.024000e+04
*** PROGRAM STOPPED: FATAL ERROR(s) ENCOUNTERED
