🎉Community Raffle - Win $25
Join and Win
Secondary pulley radius exceeded its maximum value.
User: "sudo"
Altair Community Member
I am performing a simulation of an automatic motorcycle with a CVT and gathering its data. I checked the configuration of the cvt, and it states that the maximum running radius of the secondary pulley is 55 mm. However, when I reviewed the data collected after the simulation, I noticed that in the first few records, the secondary pulley radius reached 58 mm. I’m not sure if this is a bug or if there is a specific reason for it.
This is from the cetrifugal_rubber_belt.cvt:
This is from the data that I collected:
Thanks!
1 - 6 of 61
    User: "GTT Adam"
    Altair Employee
    Hi @sudo,
    You are correct in that the limits set in the CVT file should restrict the pulley radii.
    How are you measuring the Primary Pulley and Secondary Pulley radii? Are you using the predefined Output or did you create one?
    Hope this helps!
    Adam Reid
    User: "sudo"
    OP
    Updated by sudo
    Hi @GTT Adam
    Yes, I am using that predefined Output.
    After the simulation, I used hypergraph to plot the data and export them as csv file. I selected that Pulley radii [F2 = Primary, F3 = Secondary] and selected F2 and F3 in the components selection.
    User: "GTT Adam"
    Altair Employee
    Hi @sudo,
    Ok, perfect.
    Does this maximum pulley radii violation only happen at time = 0, or does it happen throughout the simulation? Can you share a plot of the pulley radii throughout the event you are completing?
    Hope this helps!
    Adam Reid
    User: "sudo"
    OP
    Hi @GTT Adam
    Here is the link of the data that we gathered in a csv file format:
    https://drive.google.com/file/d/1z2ghNRkmnZQkVK2UVVCxq8WusLKkFNfw/view?usp=sharing
    Also here is the plt and abf files:
    User: "GTT Adam"
    Altair Employee
    Hi @sudo,
    Are you able to attach the model as a zipped model archive?
    (File >> Export >> Model >> Archive Model & Create Zip File)
    Hope this helps!
    Adam Reid
    User: "Orestis_YB"
    Altair Employee
    Accepted Answer
    Hello @sudo,
    Rmin and Rmax values in cvt file are used to saturate the radius ratio. They will not saturate the actual radius of the pulleys. These radius are calculated based on the center distance of the pulleys and the belt length.
    Hope this helps!
    Best regards,
    Orestes
