I am performing a simulation of an automatic motorcycle with a CVT and gathering its data. I checked the configuration of the cvt, and it states that the maximum running radius of the secondary pulley is 55 mm. However, when I reviewed the data collected after the simulation, I noticed that in the first few records, the secondary pulley radius reached 58 mm. I’m not sure if this is a bug or if there is a specific reason for it.
This is from the cetrifugal_rubber_belt.cvt:
This is from the data that I collected:
Thanks!
