Dsim: Syntax error when using macro in system verilog simulation
When compiling using Dsim, the compilation failed when it tried to compile this line.
`define width 4
`define init 0 … count <= `width'd`init;
By my understanding, the defined macro should be preprocessed before the compilation stage, so it should resolve to this:
count <= 4'd0;
It will be helpful if I can get away with using this way of coding as we are managing IP models running on multiple simulators from various vendors and currently other vendor simulator is able to support this code. I have attached a simple counter example on this error.
DSim 2025.0.1 fixes this issue and can be downloaded from Altair Marketplace here:
If you don't want the installer to overwrite your existing DSim installation, please make sure to change the default installation path.
@alyee_tan920 Glad to hear it. Could you accept my previous post as the Answer to your question?
DSim should resolve the defined macro properly. An internal bug report has been filed. I'll update you when the fix is available.
