Issues, ticket #100.18.11 #100.18.10 #100.18.1 #100.18.39 Hello everyone, I am new to this software
Hello, I am new to this software and I am having some issues on running the tests. I saw other people had the same problem, so I followed the guide to solve the issues but nothing changed.
Here below the error code:
The test Characterization, Thermal, Motor & Generator, Steady state failed due to the following problem:
Cause : The test cannot be completed because the job with the id 0 has created an error.
Type of the error : Unknown
Message : Unknown error
Type : Internal error
Ticket Number : #100.18.11 #100.18.10 #100.18.1 #100.18.39
I have Flux Motor and Flux 2025 version.
1 - 1 of
11
Hello,
Thanks for contacting the Altair support.
I suggest you to open the support ticket and share the zip file, in the ticket. So, we can look into the error and give you the answer. I don't recommend sharing the zip file publicly here.
Best Regards,
Charishma.
