Erorrs in Altair EDEM
Igor1337
Igor1337 Altair Community Member
Hello, I have a problem when saving a file in Altair EDEM, the following errors are displayed and I don't know how to deal with it. Maybe someone had this?
Welcome!
Answers
  • Stephen Cole
    Stephen Cole
    Altair Employee
    Hi, typically you would see this if you don't have read/write permissions on the location you are saving the file to, or the disk is full.
    Alternatively if you have the same simulation open in two versions of EDEM at the same time this can cause problems saving any changes.
    Regards
    Stephen
  • Igor1337
    @Stephen Cole Okay i see, could You tell me how can I change that permissions??
  • Stephen Cole
    Stephen Cole
    Altair Employee
    Its probably something best for system admin to do, as it may require admin rights.
    Just to add another point to try is to close all EDEM and for the simulation you are saving try renaming or deleting the simulation.dfg file and then try again.
  • Igor1337
    @Stephen Cole Im admin, because im using student version on my own computer. Renaming or deleting didnt do anything :/
  • Stephen Cole
    Stephen Cole
    Altair Employee
    Is it just the specific file, if you can save other files to that location it could be that the file has become corrupt, possibly due to a file error during saving. Could you try saving a different file or to a different location?
  • Igor1337
    edited February 26
    I fixed it by simply saving the file straight on the disc D:, for whatever reason EDEM had no permission to subfolders. Thanks for help :)
Welcome!
Welcome!
