how to come up with Plot force vs displacement curve with HyperGraph 2024
ermanh45
ermanh45 Altair Community Member
please help me bring up the curva force vs displacement data, is the setting in my hypermesh not enough to be able to bring up the data, ? I have followed the youtube video steps but the results are different, Thank you.
Welcome!
Answers
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    hi,
    from what i've seen in your model, you want to plot the force x displacement curve of your part, smashed by the pole, right?
    In order to do that, you will need to request in your Radioss model, the time history (Output Block - TH) of the green rigid body, requesting both the displacement and forces on the rbody. (DEF)
    https://help.altair.com/hwsolvers/rad/topics/solvers/rad/th_rbody_starter_r.htm#th_rbody_starter_r__th_rbody_starter_r_section_ktz_gpn_kdb
    Assuming that you have both the displacement over time, and force over time, you can cross-plot them as shown in the video you've shared.
  • Marina_Lima
    Marina_Lima
    Altair Employee
    Hi,
    In your model, there are only time histories for interface and rigid bodies (TH/INTER, TH/RBODY), these outputs register forces and moments. If you want to output displacement, you also need to add a time history that captures displacement, like a TH/NODE, for example.
  • ermanh45
    Can you show me how to input it in the form of photos or videos, I don't really understand, thank you.
  • ermanh45
    Is this what it means ?
  • Marina_Lima
    Marina_Lima
    Altair Employee
    For example, if you want to plot the Force x Displacement of RBODY ID=19 in you model, you should request on Output Blocks a TH/RBODY for this element (Force) and a TH/NODE for the main node of the RBODY (Displacement):
Welcome!
Welcome!
