As far as I understand, you are defining an RBE reference point from nodes which have only solid elements (solid element do not have rotational stiffness associated). So you need to correct your RBE3 cards and use only 123 instead of 123456
Please help me with Nastran error..
Hello~All
Help me…ㅠㅠ
I conducted the analysis using Nastran SOL103.
I am having trouble troubleshooting.
I have attached the relevant data.
Best Answer
0
Answers
Hello
You should reach out to Nastran support regarding any Nastran solver error.
Thanks
0 -
you should provide the .f06 file or part of it when FATAL occurs
0 -
0S O R T E D B U L K D A T A E C H OENTRYCOUNT . 1 .. 2 .. 3 .. 4 .. 5 .. 6 .. 7 .. 8 .. 9 .. 10 .ENDDATA
TOTAL COUNT= 1753606
INPUT BULK DATA ENTRY COUNT = 1753611
1 MODAL JANUARY 25, 2025 MSC Nastran 12/18/18 PAGE 38976
MODE SHAPE0M O D E L S U M M A R Y BULK = 0
ENTRY NAME NUMBER OF ENTRIES
CHEXA 2811
CQUAD4 820839
CTRIA3 17390
EIGRL 1
GRID 868571
MAT1 6
PSHELL 5
PSOLID 1
RBE2 566
RBE3 20249*** USER WARNING MESSAGE 285 (DML)
FATAL ERRORS WERE FOUND WHILE READING THIS BEGIN SECTION
MODEL SUMMARY DOES NOT INCLUDE COUNT OF FATAL ENTITIES
^^^^^^ >>> IFP OPERATIONS COMPLETE <<<
^^^*** USER INFORMATION MESSAGE 22964 (rmrgdrot_impl)
One or more RBE3 elements have been detected for which the dependent GRID connects to solid elements only but
dof 456 have been specified as part of REFC. In some cases, this may cause inefficient processing. Up to 50
pairs of RBE3 and REFG with this occurring are listed below.
User Action: If this is intentional, ignore this message, otherwise, you can set MDLPRM,RMRBE3RT,1 to
automatically remove dof 456 from the REFC on these RBE3s.
1855967 48743238
1855968 48743239
1855969 48743240
1855970 48743241
1855972 48743242
1855973 48743243
1855974 48743244
1855975 48743245
1855977 48743247
1855978 48743248
1855979 48743249
1855980 48743250
1855981 48743253
1855982 48743254
1855983 48743255
1855984 48743256
1855986 48743257
1855987 48743258
1855988 48743259
1855989 48743260
1855991 48743262
1855992 48743263
1855993 48743264
1855994 48743265
1855995 48743268
1855996 48743269
1855997 48743270
1855998 48743271
1856000 48743272
1856001 48743273
1856002 48743274
1 MODAL JANUARY 25, 2025 MSC Nastran 12/18/18 PAGE 38977
MODE SHAPE001856003 48743275
1856005 48743277
1856006 48743278
1856007 48743279
1856008 48743280
1856009 48743283
1856010 48743284
1856011 48743285
1856012 48743286
1858002 48743287
1858003 48743288
1858005 48743289
1858036 48743290
1858039 48743292
1858041 48743293
1859573 48743294
1859574 48743295
1859575 48743298
1859576 48743299^^^*** USER FATAL MESSAGE 9002 (SUBDMAP IFPS)
ERROR(S) ENCOUNTERED IN THE MAIN BULK DATA SECTION
SEE MESSAGES ABOVE. ERROR ENCOUNTERED IN MODULE IFP,
^^^1 MODAL JANUARY 25, 2025 MSC Nastran 12/18/18 PAGE 38978
MODE SHAPE00*** USER INFORMATION MESSAGE 4425 (PRTPRN)
ONE OR MORE FATAL ERRORS HAVE OCCURRED. THERE MAY BE MORE ERROR MESSAGES IN THE PRECEDING OUTPUT
1 MODAL JANUARY 25, 2025 MSC Nastran 12/18/18 PAGE 38979
MODE SHAPE0- D B D I C T P R I N T * * * * SUBDMAP = PRTSUM , DMAP STATEMENT NO. 71
0 * * * * A N A L Y S I S S U M M A R Y T A B L E * * * *
0 SEID PEID PROJ VERS APRCH SEMG SEMR SEKR SELG SELR MODES DYNRED SOLLIN PVALID SOLNL LOOPID DESIGN CYCLE SENSITIVITY0SEID = SUPERELEMENT ID.
PEID = PRIMARY SUPERELEMENT ID OF IMAGE SUPERELEMENT.
PROJ = PROJECT ID NUMBER.
VERS = VERSION ID.
APRCH = BLANK FOR STRUCTURAL ANALYSIS. HEAT FOR HEAT TRANSFER ANALYSIS.
SEMG = STIFFNESS AND MASS MATRIX GENERATION STEP.
SEMR = MASS MATRIX REDUCTION STEP (INCLUDES EIGENVALUE SOLUTION FOR MODES).
SEKR = STIFFNESS MATRIX REDUCTION STEP.
SELG = LOAD MATRIX GENERATION STEP.
SELR = LOAD MATRIX REDUCTION STEP.
MODES = T (TRUE) IF NORMAL MODES OR BUCKLING MODES CALCULATED.
DYNRED = T (TRUE) MEANS GENERALIZED DYNAMIC AND/OR COMPONENT MODE REDUCTION PERFORMED.
SOLLIN = T (TRUE) IF LINEAR SOLUTION EXISTS IN DATABASE.
PVALID = P-DISTRIBUTION ID OF P-VALUE FOR P-ELEMENTS
LOOPID = THE LAST LOOPID VALUE USED IN THE NONLINEAR ANALYSIS. USEFUL FOR RESTARTS.
SOLNL = T (TRUE) IF NONLINEAR SOLUTION EXISTS IN DATABASE.
DESIGN CYCLE = THE LAST DESIGN CYCLE (ONLY VALID IN OPTIMIZATION).
SENSITIVITY = SENSITIVITY MATRIX GENERATION FLAG.No PARAM values were set in the Control File.
1 * * * END OF JOB * * *
No Symbolic Replacement variables or values were specified.
0 -
0 -
Thank you.
But MDLPRM, RMRBE3RT, 1 to
How do I do this??0
