Altair RISE
Nominate Yourself Now!
Save every simulation steps result in csv
User: "sudo"
Altair Community Member
Hi!
I am using MotionView to perform a motion analysis of a two-wheeler scooter with a CVT. I can view the results using the Report tool.
However, I need to save the data (e.g., velocity, throttle, gear ratio, etc.) for every simulation step (e.g., every second or frame) into a CSV file.
How can I achieve this? Thanks in advance!
1 - 4 of 41
    User: "GTT Adam"
    Altair Employee
    Hi @sudo,
    After plotting results in HyperGraph, you can go to File » Export » Curves, then choose the CSV Blocks file type for export.
    Hope this helps!
    Adam Reid
    User: "sudo"
    OP
    Thanks for the response @GTT Adam .
    I was able to export the output to csv. However the data looks like this which doesn't contain the outputs that I need.
    I want to get these outputs (torque, belt forces, radius, etc. ) from the model:
    User: "GTT Adam"
    Altair Employee
    Accepted Answer
    Hi @sudo,
    After simulating this UTV model, I can load the results into HyperGraph via the PLT or ABF file. In this case, I will plot the lateral acceleration:
    (Ps. I am not sure why these pictures are coming out so faded. I'll update when I find out why.)
    After creating the plot, simply go to File » Export » Curves:
    It will only display the curves you had already plotted, as shown:
    Hope this helps!
    Adam Reid
    User: "sudo"
    OP
    Thanks @GTT Adam .
    I was able to gather all the outputs I need.
