Good afternoon, I’d like to share my problem: Starting with a laminate [0/45/-45/90/90/45/-45/0] with 1.5 mm thickness per layer, I carried out a free-size optimization to reduce the mass while imposing a Tsai-Hill constraint with an upper bound of 0.1. This configuration for the free-size phase has been the most effective among the ones I’ve tried, as the solver reduces the laminate’s mass from 0.83 kg to 0.04 kg while meeting the constraint. Thus, the total thickness of the laminate in the free-size phase ends up being 10.8 mm.
However, when I proceed to the SIZE (PARAMETER) optimization phase, and in the DCOMP card, I introduce a minimum laminate thickness constraint of 10 mm (so that it doesn’t reduce excessively and continues to meet the Tsai-Hill constraint), and reintroduce the mass of the structure as the objective function to minimize it further, I also slightly modify the Tsai-Hill constraint to ensure it’s still met after further mass reduction.
My issue arises when I run the optimization: No matter how many simulations I run, it never satisfies the minimum laminate thickness constraint I set in the DCOMP card, always leaving it at 1.9 mm thickness. This results in ridiculously high Tsai-Hill values. I’ve also tried using compliance as the objective function, but I still get the same strange results. What could I do?
Best Regards, Pablo
