Lisencing Error for Student version.
Dear Community,
I want to simulate the Airbag Driver crash result which is provided in this link: https://help.altair.com/hwsolvers/rad/topics/solvers/rad/airbag_example_r.htm#airbag_example_r__airbag_example_r_fig_ydr_ywz_mmb
I have downloaded the zip file with names driver_airbag_0000 and driver_airbag_0001.
I have downloaded the student version of of OptiStruct. I have also activated the Lisence.
Now I Opened Compute Console 2024.1, linked the 0000 file and ran with "options" :-nt 4.
After it ran it gave the following result of errors: kindly help me out.
** CPU USER TIME **
** SUMMARY **
#PROC CONTSORT CONTFOR ELEMENT KINCOND INTEG IO T0 ASM RESOL
1 .9312E+01 .8297E+01 .9453E+01 .3938E+01 .1125E+01 .3406E+01 .9734E+01 .8938E+01 .6303E+02
** CUMULATIVE CPU TIME SUMMARY **
CONTACT SORTING.............: .9312E+01 14.77 %
CONTACT FORCES..............: .8297E+01 13.16 %
ELEMENT FORCES..............: .9453E+01 15.00 %
KINEMATIC COND..............: .3938E+01 6.25 %
INTEGRATION.................: .1125E+01 1.78 %
ASSEMBLING..................: .8938E+01 14.18 %
OTHERS (including I/O)......: .2197E+02 34.85 %
TOTAL.......................: .6303E+02 100.00 %
** MEMORY USAGE STATISTICS **
TOTAL MEMORY USED .........................: 446 MB
MAXIMUM MEMORY PER PROCESSOR...............: 446 MB
MINIMUM MEMORY PER PROCESSOR...............: 446 MB
AVERAGE MEMORY PER PROCESSOR...............: 446 MB
** DISK USAGE STATISTICS **
TOTAL DISK SPACE USED .....................: 40 MB
ANIMATION/H3D/TH/OUTP SIZE ................: 17 MB
RESTART FILE SIZE .........................: 22 MB
ELAPSED TIME = 19.34 s
0:00:19
NORMAL TERMINATION
TOTAL NUMBER OF CYCLES : 40003
License error:
Altair License Manager: License error
Feature(s): GlobalZoneAP, HyperWorks, HWRadioss
Error Code: 9
Error Description:
Feature not found
Feature: Radioss
Error Code: 6
Error Description:
[LOCAL] C:\Users\Bibek Bhattacharyya\AppData\Local.altair_licensing\Bibeks-PC13-001\licenses\L2N6C-YXKWK-9C3P5-TPYGW.lic - (Err: 9) Feature not found
[LOCAL] C:/Program Files/Altair/2024.1/security/altair_lic.dat - (Err: 6) Unable to read file
License Path: C:/Program Files/Altair/2024.1\security\altair_lic.dat;C:\Users\Bibek Bhattacharyya\AppData\Local.altair_licensing\Bibeks-PC13-001\licenses;C:/Program Files/Altair/2024.1/security/altair_lic.dat
Altair Managed Licensing: License error
Feature: Radioss
Error Code: -40
Error Description:
[LicID -1] (Err: -40) While checking out feature "GlobalZoneAP": Requested feature name was not found in licenses
==== End of solver screen output ====
==== Radioss Job completed ====
Answers
Hi,
Can you please import the files into HyperMesh and solve through the Analyze > Radioss Solver option
1 -
Hey Rahul, Thank you so much. It worked.
However, now I want to give a certain velocity to the Head inside the simulation. How can i perform that.
Could you guide me a bit?0 -
This being a basic function, please refer to the help documentation and Radioss tutorials in help to learn to use the software, you can also see courses and other learning material in learn.altair.com
In general, you can ask Radioss questions with a tag Radioss in this community so that Radioss experts can assist you,
0
