Altair RISE
Nominate Yourself Now!
*** FATAL ERROR # 3205 *** Nonlinear analysis cannot proceed due to excessive mesh distortion.
User: "Varshith_reddy_8"
Altair Community Member
I have the following error in my simulation, Can someone explain me.. how to avoid the error without remeshing the model. This error only occur when Iam using MATS1
1 - 3 of 31
    User: "loistf"
    Hi. Have you tried as the out file suggests? Do you know how to achieve those recommendations?
    OP
    I have no idea how to acheive the recommendations
    User: "loistf"
    Hi @Varshith_reddy_8
    The message recommends you to define lower values than default for epsu, epsp, epsw.
    https://2024.help.altair.com/2024/hwsolvers/os/topics/solvers/os/nlparm_bulk_r.htm
    Also, use a bigger number than default for NINC.
    You can do that both with your text editor and via HyperMesh too.
    Hope that helps.
