I have the following error in my simulation, Can someone explain me.. how to avoid the error without remeshing the model. This error only occur when Iam using MATS1
Hi. Have you tried as the out file suggests? Do you know how to achieve those recommendations?
I have no idea how to acheive the recommendations
Hi @Varshith_reddy_8
The message recommends you to define lower values than default for epsu, epsp, epsw. https://2024.help.altair.com/2024/hwsolvers/os/topics/solvers/os/nlparm_bulk_r.htm
Also, use a bigger number than default for NINC.
You can do that both with your text editor and via HyperMesh too.
Hope that helps.
