Issue with Altair Inspire OptiStruct License in Personal Edition
Kaminari
Kaminari Altair Community Member
edited November 2024 in Community Q&A
Hi, I recently downloaded the program and I am experiencing an issue with the OptiStruct license in Altair Inspire Personal Edition and would appreciate any help you can provide.
Specifically, when I try to run a topology optimization, an error message appears indicating that a license for Inspire OptiStruct Solver feature couldn't be found. The message suggests checking the network connection and ensuring a valid license file is available. I am not sure how to fix it. Attached is a screenshot of the error message for clarity.
Welcome!
Answers
  • nitramgorre
    nitramgorre New Altair Community Member
    I am having the same issue with Inspire 2024.1.1 on a Personal Edition, even if I just do the tutorials. Did you manage to resolve it ?
  • Stein
    Stein New Altair Community Member
    I am experiencing the same license issue as you: Unable to find a license for the Inspire OptiStruct Solver feature. The only difference is that my error message states: 'A license for the feature %1 could not be found.' Any ideas?
  • Kaminari
    Still without a solution 😞
  • Rahul_P1
    Rahul_P1
    Altair Employee
    HI,
    Please request for a personal edition again and download the latest exe to bypass this error.
  • Frank_Herrmann
    Frank_Herrmann Altair Community Member
    Hi Rahul_P1, requesting for a new personal edition does not solve the problem. The problem remains the same: When a run is started with run options set to OptiStruct you can follow it in the run folder. The preprocessing is doing fine. But when the OptiStruct should start the run ends with a fatal error. Opening in the run folder the file "optiAnalysis.out" gives the following information:
    THE FOLLOWING ERROR MESSAGE WAS RETRIEVED FROM THE LICENSE SERVER
    Altair License Manager: License error
    Feature(s): InspireOSSolverPE
    Error Code: 12
    Error Description:
    Software expired
    License Path: C:\Program Files\Altair\2024.1Pers\InspirePersonal2024.1.1\hwx\bin\win64\security\altair_lic.dat;C:\Program Files\Altair\2024.1Pers\InspirePersonal2024.1.1\hwx\bin\win64/security/altair_lic.dat
    Feature(s): GlobalZoneEU, HyperWorksEDU
    Error Code: 9
    Error Description:
    Feature not found
    No Available License
    My question now is: Do I have to do any handling with any altair_lic.dat file? I just executed the AltairInspirePersonal2024.1.1_win64.exe and that's it. Is there a misunderstanding from my side?
    Thanks for any help and best regards, Frank
  • Rahul_P1
    Rahul_P1
    Altair Employee
    HI, you dont need a license file for the personal edition, we will notify the development team, Please request and use the free student edition which you are eligible to as a student at university -https://community.altair.com/discussion/34207/instructions-to-access-the-free-altair-student-edition-now-in-altair-one#latest
  • DDL01
    DDL01 Altair Community Member
    Hi Rahul, has this issue been resolved for Inspire Personal? I requested and downloaded and installed the latest version (which however is still 2024.1.1. If I try to run an Optistruct solver I get the same error message (license for Inspire Optistruct Solver feature cannot be found).
  • Rahul_P1
    Rahul_P1
    Altair Employee
    Hi @DDL01 The issue is fixed in 2025.1 yet to be released, but I will send a tool that you can run in the command line to reset the license and make the personal edition work …
  • DDL01
    Thanks Rahul!
  • DDL01
    Hi Rahul, let me know when you can send the command line tool and instructions to reset the license. Thanks.
  • Rahul_P1
    Rahul_P1
    Altair Employee
    Hi, the license tool was sent to you.
  • DDL01
    Thanks Rahul. That worked for me.
Welcome!
Welcome!
