Can't retrieve repository data
shashwat01
shashwat01 Altair Community Member
edited November 2024 in Community Q&A
I am trying to Import the process flow but is getting the following error, please see the attached screenshot.
2.PNG 217.1K
1.PNG 218.4K
5.PNG 284.7K
3.PNG 346.4K
4.PNG 480.7K
Welcome!
Best Answer
  • RolandJones
    RolandJones
    Altair Employee
    Answer ✓
    Hi @shashwat001,
    Am I correct that you're trying to retrieve the "Dataset-Hotel+Booking+Cancellation+Prediction" dataset from the repository. In this case you need a Retrieve operator, which if you click on it you will see has a single parameter called "repository entry".
    If you click the small folder icon, it will allow you to navigate to your dataset:
    Click OK, and then now when I click Run it will retrieve that dataset for me.
    Best,
    Roland
Answers
Welcome!
Welcome!
