Altair RISE
Nominate Yourself Now!
Can't retrieve repository data
shashwat01
I am trying to Import the process flow but is getting the following error, please see the attached screenshot.
RolandJones
Hi
@shashwat001
Am I correct that you're trying to retrieve the "Dataset-Hotel+Booking+Cancellation+Prediction" dataset from the repository. In this case you need a Retrieve operator, which if you click on it you will see has a single parameter called "repository entry".
If you click the small folder icon, it will allow you to navigate to your dataset:
Click OK, and then now when I click Run it will retrieve that dataset for me.
Best,
Roland
RolandJones
Hi
@shashwat001
The error shown appears to suggest that the Retrieve operator at the start of your process isn't pointing at your data. Could you possibly verify the entry in the Parameters pane for the Retrieve operator, and ensure it's set to your dataset?
Best,
Roland
shashwat01
Thank you for the support so far, but the issue is still not resolved. I have shared more screenshots.
Also. in the parametric panel, i do not see any path; you can check the screenshot if the retrieve function was properly used.
Thanks. I will be waiting for further support.
RolandJones
Hi
@shashwat001
In your first message, you were trying to retrieve data from "//Temporary Repository/SPAM-text-message (2)" which didn't exist. This is why I asked you to check the parameters pane on the Retrieve operator, to make sure it's pointing to a valid dataset.
In one of your errors in the second message, it looks as though you are trying to Retrieve something different. If you want to run other processes as part of a new process, I recommend you look at the "Execute Process" operator.
Best,
Roland
shashwat01
Please can you show me the below. I don't see data_set. I have attached a screenshot. Can you show a picture of how you carry out points 1 and 2?
1. Select the Retrieve operator.
2. In the Parameters pane, set the `data_set` to `Local Repository/processes/Dataset-Hotel+Booking+Cancellation+Prediction`
Attaching relevant files as well.
RapidMiner File - Hotel Booking Cancellation Prediction (Random Forest)-1.rmp
RapidMiner File - Hotel Booking Cancellation Prediction (Decision Tree).rmp
RapidMiner File - Hotel Booking Cancellation Prediction (Random Forest - Pruned) (1).rmp
RapidMiner File - Hotel Booking Cancellation Prediction (Decision Tree - Pruned).rmp
Dataset-Hotel+Booking+Cancellation+Prediction.csv
RolandJones
Hi
@shashwat001
Best,
Roland
