Memory buffered file
toàn
New Altair Community Member
I want to convert matrix shape 28x28 to 1x784, i use execute python to do it, this code below here but result moniter Memory buffered file. Can you fix this problem, thanks !
0
Best Answer
And by the way, there is no need for python if you use the Image Processing extension.
0
Answers
Hey,basically everything that is not a pd.DataFrame is pickled and you get the pickled version. This is then the purple fileobject, which you cannot use with any operator in RM, other than another Exec Python operator.-> You want to return a pd.DataFrame here.Best,Martin0
0 -
hey martin,
you think i should use another operator in image proccess to convert?
0 -
0 -
Hi @tóan,yes. I would do it like this:This is the process:Spoiler
<?xml version="1.0" encoding="UTF-8"?><process version="10.3.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="10.3.000" expanded="true" name="Process">
<parameter key="logverbosity" value="init"/>
<parameter key="random_seed" value="2001"/>
<parameter key="send_mail" value="never"/>
<parameter key="notification_email" value=""/>
<parameter key="process_duration_for_mail" value="30"/>
<parameter key="encoding" value="SYSTEM"/>
<process expanded="true">
<operator activated="true" class="image_processing:read_image" compatibility="0.3.002" expanded="true" height="68" name="Read Image" width="90" x="179" y="34">
<parameter key="file" value="C:/Users/MartinSchmitz/Downloads/Capture.PNG"/>
<parameter key="show_pdf_options" value="false"/>
<parameter key="dpi" value="300"/>
<parameter key="read_all_pages" value="false"/>
<parameter key="enforce_pdf" value="false"/>
<description align="center" color="transparent" colored="false" width="126">Change the path here</description>
</operator>
<operator activated="true" class="image_processing:color_convert" compatibility="0.3.002" expanded="true" height="82" name="Convert Color" width="90" x="313" y="34">
<description align="center" color="transparent" colored="false" width="126">Turns it into B/W</description>
</operator>
<operator activated="true" class="image_processing:resize_image" compatibility="0.3.002" expanded="true" height="82" name="Resize Image" width="90" x="447" y="34">
<parameter key="width" value="100"/>
<parameter key="height" value="100"/>
<description align="center" color="transparent" colored="false" width="126">for speed reasons just 100x100</description>
</operator>
<operator activated="true" class="image_processing:img_to_table" compatibility="0.3.002" expanded="true" height="82" name="Image to Table" width="90" x="581" y="34"/>
<operator activated="true" class="blending:generate_id" compatibility="10.3.000" expanded="true" height="82" name="Generate ID" width="90" x="715" y="34">
<parameter key="create_nominal_ids" value="false"/>
<parameter key="offset" value="1"/>
</operator>
<operator activated="true" class="blending:pivot" compatibility="10.3.000" expanded="true" height="103" name="Pivot" width="90" x="849" y="34">
<parameter key="group_by_attributes" value=""/>
<parameter key="column_grouping_attribute" value="id"/>
<list key="aggregation_attributes"/>
<parameter key="use_default_aggregation" value="true"/>
<parameter key="default_aggregation_function" value="first"/>
</operator>
<operator activated="true" class="rename_by_replacing" compatibility="10.3.000" expanded="true" height="82" name="Rename by Replacing" width="90" x="983" y="34">
<parameter key="attribute_filter_type" value="all"/>
<parameter key="attribute" value=""/>
<parameter key="attributes" value=""/>
<parameter key="use_except_expression" value="false"/>
<parameter key="value_type" value="attribute_value"/>
<parameter key="use_value_type_exception" value="false"/>
<parameter key="except_value_type" value="time"/>
<parameter key="block_type" value="attribute_block"/>
<parameter key="use_block_type_exception" value="false"/>
<parameter key="except_block_type" value="value_matrix_row_start"/>
<parameter key="invert_selection" value="false"/>
<parameter key="include_special_attributes" value="false"/>
<parameter key="replace_what" value="first\(Column(\d+)\)_(\d+)"/>
<parameter key="replace_by" value="$1_$2"/>
</operator>
<connect from_op="Read Image" from_port="img" to_op="Convert Color" to_port="image input"/>
<connect from_op="Convert Color" from_port="image output" to_op="Resize Image" to_port="image input"/>
<connect from_op="Resize Image" from_port="image output" to_op="Image to Table" to_port="img"/>
<connect from_op="Image to Table" from_port="exa" to_op="Generate ID" to_port="example set input"/>
<connect from_op="Generate ID" from_port="example set output" to_op="Pivot" to_port="input"/>
<connect from_op="Pivot" from_port="output" to_op="Rename by Replacing" to_port="example set input"/>
<connect from_op="Rename by Replacing" from_port="example set output" to_port="result 1"/>
</process>
</operator>
</process>BR,Martin
0 -
thank you0
