<?xml version="1.0" encoding="UTF-8"?><process version="10.3.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="10.3.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="image_processing:read_image" compatibility="0.3.002" expanded="true" height="68" name="Read Image" width="90" x="179" y="34"> <parameter key="file" value="C:/Users/MartinSchmitz/Downloads/Capture.PNG"/> <parameter key="show_pdf_options" value="false"/> <parameter key="dpi" value="300"/> <parameter key="read_all_pages" value="false"/> <parameter key="enforce_pdf" value="false"/> <description align="center" color="transparent" colored="false" width="126">Change the path here</description> </operator> <operator activated="true" class="image_processing:color_convert" compatibility="0.3.002" expanded="true" height="82" name="Convert Color" width="90" x="313" y="34"> <description align="center" color="transparent" colored="false" width="126">Turns it into B/W</description> </operator> <operator activated="true" class="image_processing:resize_image" compatibility="0.3.002" expanded="true" height="82" name="Resize Image" width="90" x="447" y="34"> <parameter key="width" value="100"/> <parameter key="height" value="100"/> <description align="center" color="transparent" colored="false" width="126">for speed reasons just 100x100</description> </operator> <operator activated="true" class="image_processing:img_to_table" compatibility="0.3.002" expanded="true" height="82" name="Image to Table" width="90" x="581" y="34"/> <operator activated="true" class="blending:generate_id" compatibility="10.3.000" expanded="true" height="82" name="Generate ID" width="90" x="715" y="34"> <parameter key="create_nominal_ids" value="false"/> <parameter key="offset" value="1"/> </operator> <operator activated="true" class="blending:pivot" compatibility="10.3.000" expanded="true" height="103" name="Pivot" width="90" x="849" y="34"> <parameter key="group_by_attributes" value=""/> <parameter key="column_grouping_attribute" value="id"/> <list key="aggregation_attributes"/> <parameter key="use_default_aggregation" value="true"/> <parameter key="default_aggregation_function" value="first"/> </operator> <operator activated="true" class="rename_by_replacing" compatibility="10.3.000" expanded="true" height="82" name="Rename by Replacing" width="90" x="983" y="34"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="replace_what" value="first\(Column(\d+)\)_(\d+)"/> <parameter key="replace_by" value="$1_$2"/> </operator> <connect from_op="Read Image" from_port="img" to_op="Convert Color" to_port="image input"/> <connect from_op="Convert Color" from_port="image output" to_op="Resize Image" to_port="image input"/> <connect from_op="Resize Image" from_port="image output" to_op="Image to Table" to_port="img"/> <connect from_op="Image to Table" from_port="exa" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Pivot" to_port="input"/> <connect from_op="Pivot" from_port="output" to_op="Rename by Replacing" to_port="example set input"/> <connect from_op="Rename by Replacing" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
