Altair RISE
Nominate Yourself Now!
Extracting a number from a string under specific conditions
User: "paolochip"
Altair Employee
Updated by Jocelyn
Hi,
I'm struggling on doing something that looks easy (and maybe dumb), but I don't find a way. I need to extract a number from a string that matches specific conditions. I have a column with different strings like:
John Alpha U23
Mike Beta C57
Ann Cole U73456
Amy Utta J94857
I want RM to create a new colum that picks only numbers where there is the U in front and leave blank (or put something like none) on the other rows
23
none
73456
none
I'm not able to uniquely identify strings that contains both U and a number after. Is there a way to do that without using python or generativeAI blocks? By using a Split block with a regular expression like [^U[0-9]]{1,} it picks also the U of Amy, while I want select U only if it has followed by a number.
Thanks,
Paolo
1 - 4 of 41
    User: "MartinLiebig"
    Altair Employee
    Updated by MartinLiebig
    Here we go, this should do it:
    <?xml version="1.0" encoding="UTF-8"?><process version="10.2.000">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="10.2.000" expanded="true" name="Process">
    <parameter key="logverbosity" value="init"/>
    <parameter key="random_seed" value="2001"/>
    <parameter key="send_mail" value="never"/>
    <parameter key="notification_email" value=""/>
    <parameter key="process_duration_for_mail" value="30"/>
    <parameter key="encoding" value="SYSTEM"/>
    <process expanded="true">
    <operator activated="true" class="utility:create_exampleset" compatibility="10.2.000" expanded="true" height="68" name="Create ExampleSet" width="90" x="246" y="34">
    <parameter key="generator_type" value="comma separated text"/>
    <parameter key="number_of_examples" value="100"/>
    <parameter key="use_stepsize" value="false"/>
    <list key="function_descriptions"/>
    <parameter key="add_id_attribute" value="false"/>
    <list key="numeric_series_configuration"/>
    <list key="date_series_configuration"/>
    <list key="date_series_configuration (interval)"/>
    <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/>
    <parameter key="time_zone" value="SYSTEM"/>
    <parameter key="input_csv_text" value="attribute&#10;John Alpha U23&#10;Mike Beta C57&#10;Ann Cole U73456&#10;Amy Utta J94857"/>
    <parameter key="column_separator" value=","/>
    <parameter key="parse_all_as_nominal" value="true"/>
    <parameter key="decimal_point_character" value="."/>
    <parameter key="trim_attribute_names" value="true"/>
    </operator>
    <operator activated="true" class="generate_copy" compatibility="10.2.000" expanded="true" height="82" name="Generate Copy" width="90" x="447" y="34">
    <parameter key="attribute_name" value="attribute"/>
    <parameter key="new_name" value="number"/>
    </operator>
    <operator activated="true" class="replace" compatibility="10.2.000" expanded="true" height="82" name="Replace" width="90" x="581" y="34">
    <parameter key="attribute_filter_type" value="single"/>
    <parameter key="attribute" value="number"/>
    <parameter key="attributes" value=""/>
    <parameter key="use_except_expression" value="false"/>
    <parameter key="value_type" value="nominal"/>
    <parameter key="use_value_type_exception" value="false"/>
    <parameter key="except_value_type" value="file_path"/>
    <parameter key="block_type" value="single_value"/>
    <parameter key="use_block_type_exception" value="false"/>
    <parameter key="except_block_type" value="single_value"/>
    <parameter key="invert_selection" value="false"/>
    <parameter key="include_special_attributes" value="false"/>
    <parameter key="replace_what" value="[\w|\s]+ U(\d+)"/>
    <parameter key="replace_by" value="$1"/>
    </operator>
    <operator activated="true" class="parse_numbers" compatibility="10.2.000" expanded="true" height="82" name="Parse Numbers" width="90" x="715" y="34">
    <parameter key="decimal_character" value="."/>
    <parameter key="grouped_digits" value="false"/>
    <parameter key="grouping_character" value=","/>
    <parameter key="infinity_representation" value=""/>
    <parameter key="unparsable_value_handling" value="replace with missing values"/>
    </operator>
    <connect from_op="Create ExampleSet" from_port="output" to_op="Generate Copy" to_port="example set input"/>
    <connect from_op="Generate Copy" from_port="example set output" to_op="Replace" to_port="example set input"/>
    <connect from_op="Replace" from_port="example set output" to_op="Parse Numbers" to_port="example set input"/>
    <connect from_op="Parse Numbers" from_port="example set output" to_port="result 1"/>
    </process>
    </operator>
    </process>
    User: "paolochip"
    Altair Employee
    OP
    It works! :)
    Thanks a lot for your super fast reply!
    User: "CKönig"
    New Altair Community Member
    User: "Tiimm"
    which operator is used for this?
    Icoon voor Geverifieerd door de community
