I'm struggling on doing something that looks easy (and maybe dumb), but I don't find a way. I need to extract a number from a string that matches specific conditions. I have a column with different strings like:
| John Alpha U23 |
| Mike Beta C57 |
| Ann Cole U73456 |
| Amy Utta J94857 |
I want RM to create a new colum that picks only numbers where there is the U in front and leave blank (or put something like none) on the other rows
I'm not able to uniquely identify strings that contains both U and a number after. Is there a way to do that without using python or generativeAI blocks? By using a Split block with a regular expression like [^U[0-9]]{1,} it picks also the U of Amy, while I want select U only if it has followed by a number.
Thanks,
Paolo
