🎉Community Raffle - Win $25
Join and Win
"Java could not be launched error"
User: "ilginkocak"
New Altair Community Member
Updated by Jocelyn
Hello, I cannot use rapidminer. This is my first time so i cannot undertand what's wrong. When i install it, I don't see any .bat form of the application i only have .exe
It seems Error Code 1, but i dont only know what that means
1 - 10 of 101
    hi,
    can you check rapidminer-studio.log in
    $USER/.RapidMiner
    that should have more information.
    Best,
    Martin
    User: "CKönig"
    Additionally, what is the path to your Windows userhome?
    You can find out by opening a command line and using this command:
    echo %userprofile%
    User: "ilginkocak"
    OP
    please help i couldnt do it
    Hi,
    what exactly is your problem?
    Best,
    Martin
    User: "ilginkocak"
    OP
    i downloaded java, controlled my memory, everything seems normal. i use asus zenbook 13 i7 so my computer is enough to run the program i assume. i checked windows defender but i couldnt find any problem.  It just keeps saying java couldnt be launched.
    User: "ilginkocak"
    OP
    also i am not an engineering student so i need more coherent information the tackle this problem. step by step if thats possible.
    Hi,
    to identify your problem, we have to have a look at the error message, which is in the log file.
    On windows the log file named rapidminer-studio.log is located at
    C:\Users\USERNAME\.RapidMiner
    Best,
    Martin
    User: "ilginkocak"
    OP
    Updated by ilginkocak
    I found a rapidminer-studio.log file but its name is rapidminer-studio.log.lck and it seems empty.
    Is there maybe a file called rapidminer-stuido? Sometimes windows just doesnt show the ending.
    User: "Guru Charan"
    Altair Employee
