I tried to install rapid miner extension on clicking marketplace i got error stating "Cannot connect to marketplace check your internet connection or proxy setting" Although i have an active fast internet connection. Attached screenshot
this usually happens if you are behind a firewall that is blocking access. Please try to ping https://marketplace.rapidminer.com. If this is not working, please check your proxy settings.
An alternative is to Install extensions manually for RapidMiner Studio - https://community.rapidminer.com/discussion/50333/install-extensions-manually-for-rapidminer-studio
