My Rapidminer does not start correctly and I do not know what the problem is. I cannot create a local repository, the program says that it does not have the permissions but I have given all the permissions to all the files.
java.net.BindException: Permission denied (Bind failed)
at java.net.PlainDatagramSocketImpl.bind0(Native Method)
at java.net.AbstractPlainDatagramSocketImpl.bind(AbstractPlainDatagramSocketImpl.java:93)
ADVERTENCIA: Cannot retrieve key, probably no one was created: java.io.IOException: Cannot retrieve key: /home/argos98p/.RapidMiner/cipher.key (No such file or directory)
ADVERTENCIA: Failed to create default repository.
com.rapidminer.repository.RepositoryException: java.io.FileNotFoundException: No such directory /home/argos98p/Documents/RapidMiner/Local Repository
those are the first errors in the logs. My java -version: openjdk version "1.8.0_312"
OpenJDK Runtime Environment (build 1.8.0_312-8u312-b07-0ubuntu1~20.04-b07)
OpenJDK 64-Bit Server VM (build 25.312-b07, mixed mode)
Can you help me?
