Unable to start rapid miner server service on Windows 10
I want to start my rapidminer server service on my Windows 10 computer. However, the service always starts but immediately stops regardless of the method I used for starting it.
Here is the display when using the command: net start RMSSVC
The RapidMiner_Server service is starting.
The RapidMiner_Server service could not be started.
The service did not report an error.
More help is available by typing NET HELPMSG 3534.
I tried typing NET HELPMSG 3534 but it says:
I also tried running it using services.msc but it says :
The rapidminer server service on local computer started and then stopped. Some services stop automatically if they are not in used by other services or programs.
I tried running the standalone.bat file as administrator but nothing happends also.
