Unable to start rapid miner server service on Windows 10
Octopus
Octopus New Altair Community Member
I want to start my rapidminer server service on my Windows 10 computer. However, the service always starts but immediately stops regardless of the method I used for starting it.
Here is the display when using the command: net start RMSSVC
The RapidMiner_Server service is starting.
The RapidMiner_Server service could not be started.
The service did not report an error.
More help is available by typing NET HELPMSG 3534.
I tried typing NET HELPMSG 3534 but it says:
I also tried running it using services.msc but it says :
The rapidminer server service on local computer started and then stopped. Some services stop automatically if they are not in used by other services or programs.
I tried running the standalone.bat file as administrator but nothing happends also.
Welcome!
  • David Perez_20831
    David Perez_20831 New Altair Community Member
    same same...
  • aschaferdiek
    aschaferdiek New Altair Community Member
    If you start by using standalone.bat file, can you attach the log output here? Also the server.log file would be interesting to see. It resides in the RapidMiner AI Hub home directory under logs/.
  • Octopus
    Hi! Right now, I am having a new problem. I can now run my Rapidminer Server Service, However, I noticed that it keeps on disconnecting and it always shows that "No webpage was found for the web address: http://localhost:8080" whenever I started the Rapidminer server. It seems that Rapidminer is very inconsistent.
  • aschaferdiek
    As mentioned, can you please attach the log files so we can have a look?
Welcome!
Welcome!
