🎉Community Raffle - Win $25
Join and Win
How to get confusion matrix when carrying out classification cross-validation
User: "gwin"
New Altair Community Member
Updated by Jocelyn
Hello,
I have been trying to get my confusion matrix from when carrying out K means cross validation for my data set but it has been abortive. Can anyone help?
I have attached my process below.
Thank you.
1 - 6 of 61
    Hi,
    kmeans is clustering, meaning its an unsupervised method. How do you define a confusion matrix here?
    Best,
    Martin
    User: "gwin"
    OP
    hello,
    So sorry I mixed things up, what I was doing was classification matrix (I later did K-Means but not for this process). But my question is why I could my cross-validation tool (during classification) not carry out my test and training set(at the same time) and bring out a confusion matrix table. When I tried looking for the performance vector (in my testing panel) from the performance tool, it seem not to bring out the performance vector option so that I can see the confusion matrix. (I hope this is clear).
    I have attached the process again.
    Best Regards,
    Godwin
    Hi,
    maybe just because you did not connect the per port of x-validation to the right hand side?
    Cheers,
    Martin
    User: "gwin"
    OP
    Hello,
    Thanks for the speedy response.
    And yes that works for me if I want to get only the confusion matrix but then my professor's version can get the matrix even when he connects mod (instead of per) to res (and then right-click the performance inside the cross-validation to see the performance vector but I can't see it in mine when I follow the same steps).
    I hope it is clear.
    Godwin
    User: "MartinLiebig"
    Altair Employee
    Accepted Answer
    Hi,
    try to turn off the parallelization of cross validation. Then you can see the last iteration's value.
    Best,
    Martin
    User: "gwin"
    OP
    Accepted Answer
    Hello,
    It worked!
    Thanks a lot for this.
    Best Regards,
    Godwin
