RapidMiner Studio 9.9 new install on Windows 10 (Education Edition) keeps crashing on startup
Hi,
I've just installed RapidMiner for the first time and it keeps crashing on startup.
If I rerun and select "Disable Extensions" it starts. I haven't installed any new extensions as this is new install. Can anyone offer some insight into how I fault find or fix this?
Haven't used RapidMiner before.
Thanks.
Thanks.
1 - 2 of
21
- Go to your user home folder and switch to the /.RapidMiner subfolder.
- On a windows machine this will be typically C:\Users\<username\.Rapidminer
- Open the rapidminer-studio.log file. It is generated each time RapidMiner Studio is started. The file for the pre-startup phase is called launcher.log .
- Please note that there will also be some files like rapidminer-studio.log.1, rapidminer-studio.log.2 These are old historical files.
Hi @AndrewX ,
can you please check your rapidminer-studio.log? Anything suspicious in there, especially in the end?
Best
Martin
Hi @mschmitz,
Thanks for the response. It's typical, after two days of crashes, as soon as I post about it, it starts to work. Only thing I did was go and open the log file beforehand. So don't know what happened there. Anyhow, I've been trying reopening a few times to see if I can replicate the failure I was having, but so far so good.
Cheers,
Andrew
Cheers,
Andrew
1 - 1 of
11
Hi @AndrewX ,
Best
Martin
