RapidMiner Studio (Education License): Java Could Not Be Launched
SeanMaier
New Altair Community Member
Java with RapidMiner has decided on normal start-up 16GB of Ram isn't enough as of today. This is a significant issue as the license I am using is for education in remote classes and I will be unable to complete any assignments or quizzes if it is not fixed. RapidMiner will start if launched in Safe Mode without certain extensions like Optimize Parameters active, but this is not helpful as require those operators.
Instructors have no idea and thank you for any help you can give me ASAP.
0
Best Answer
Hi @SeanMaier,
Some new ideas:
did you installed some program after Rapidminer?
are you running the x32 or x64 version?Regards-1
Answers
I tried the uninstall with the deletion and disabled all antivirus software, neither worked. When RapidMiner is launching the OpenDJK does end up consuming upwards of 75% CPU and 3000MB of Ram. I do not know if that is related.0
*I also fully uninstalled antivirus and completely disabled Windows Defender. I forgot to mention that, but that did not work either.0
Hi @SeanMaier,
Some new ideas:
are you running the x32 or x64 version?Regards-1 -
Sorry for the wait! That appears to have done the trick and RapidMiner is launching normally now. Hopefully, it stays that way!0
