🎉Community Raffle - Win $25
Join and Win
[RM 9.6] Radoop Process Failed with java.net.SocketTimeoutException
User: "c0251"
New Altair Community Member
Updated by Jocelyn
Hi,
We encountered an issue which our Radoop process failed to run with following error:
2021-01-15 12:34:02.234 ERROR 22662 --- [taskScheduler-1] c.r.e.j.service.ErrorReporterService     : Exception during execution
eu.radoop.exception.NoStackTraceOperatorException: HiveQL error. Message: org.apache.thrift.transport.TTransportException: java.net.SocketTimeoutException: Read timed out
Caused by: java.sql.SQLException: org.apache.thrift.transport.TTransportException: java.net.SocketTimeoutException: Read timed out
We have tried to increase the hive.metastore.client.socket.timeout parameter on the Radoop connection but the issue persisted as well. May we require you kindly suggest how to solve issue. The Hadoop distribution is CDH 6.3.3.
Thanks!
1 - 2 of 21
    HI @c0251,
    is this a commercial support request or are you on community support?
    Best,
    Martin
    User: "c0251"
    OP
    Updated by c0251
    Hi Martin,
    Looking for help in community support.
    Best Regards,
    c0251
