Substitute Search result in RegEx with new line doesn't work
Hyperrick
New Altair Community Member
Hello support team,
I might found a bug in the RegEx implementation of Rapidminer.
My goal is to replace a "blank" with a "new line" character.
Searching in following Text:
Sri Lanka
Using the Replace operator:
Search for
Replace with:
\n
leads to:
SrinLanka
I created a workaround using the "split" operator which you also can see in my sample process.
So the question is: Is it possible to create a new line with RegEx in RM?
Kind Regards,
Patrick
Sri Lanka
Search for
Replace with:
\n
leads to:
SrinLanka
<?xml version="1.0" encoding="UTF-8"?><process version="9.7.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.7.002" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="text:create_document" compatibility="9.3.001" expanded="true" height="68" name="Create Document" width="90" x="112" y="136"> <parameter key="text" value="Sri Lanka"/> <parameter key="add label" value="false"/> <parameter key="label_type" value="nominal"/> </operator> <operator activated="true" class="text:documents_to_data" compatibility="9.3.001" expanded="true" height="82" name="Documents to Data" width="90" x="246" y="136"> <parameter key="text_attribute" value="text"/> <parameter key="add_meta_information" value="true"/> <parameter key="datamanagement" value="double_sparse_array"/> <parameter key="data_management" value="auto"/> <parameter key="use_processed_text" value="false"/> </operator> <operator activated="true" class="multiply" compatibility="9.7.002" expanded="true" height="103" name="Multiply" width="90" x="447" y="136"/> <operator activated="true" class="split" compatibility="9.7.002" expanded="true" height="82" name="Split" width="90" x="648" y="289"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="split_pattern" value=" "/> <parameter key="split_mode" value="ordered_split"/> </operator> <operator activated="true" class="transpose" compatibility="9.7.002" expanded="true" height="82" name="Transpose" width="90" x="782" y="289"/> <operator activated="true" class="replace" compatibility="9.7.002" expanded="true" height="82" name="Replace" width="90" x="648" y="34"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="replace_what" value="( )"/> <parameter key="replace_by" value="\n"/> </operator> <connect from_op="Create Document" from_port="output" to_op="Documents to Data" to_port="documents 1"/> <connect from_op="Documents to Data" from_port="example set" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Replace" to_port="example set input"/> <connect from_op="Multiply" from_port="output 2" to_op="Split" to_port="example set input"/> <connect from_op="Split" from_port="example set output" to_op="Transpose" to_port="example set input"/> <connect from_op="Transpose" from_port="example set output" to_port="result 2"/> <connect from_op="Replace" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator> </process>
Patrick
0
Answers
I am not sure how useful is this as the solution is a hack. Switch to the XML view of your process (you can bring in the XML panel in from View > Show Panel > XML, or you can edit the RMP text file directly). In the XML file find the "\n" string which you have entered in the Replace operator and change it to " ". If you worked in the XML panel, click the tick, switch back to the Process view and run. Here is an example from your process.Spoiler<?xml version="1.0" encoding="UTF-8"?><process version="9.8.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.8.000" expanded="true" name="Process">
<operator activated="true" class="text:create_document" compatibility="9.3.001" expanded="true" height="68" name="Create Document" width="90" x="45" y="34">
</operator>
<operator activated="true" class="text:documents_to_data" compatibility="9.3.001" expanded="true" height="82" name="Documents to Data" width="90" x="179" y="34">
</operator>
<operator activated="true" class="replace" compatibility="9.8.000" expanded="true" height="82" name="Replace" width="90" x="313" y="34">
<parameter key="attribute_filter_type" value="single"/>
<parameter key="attribute" value="text"/>
<parameter key="replace_by" value=" "/>
</operator>
<connect from_op="Documents to Data" from_port="example set" to_op="Replace" to_port="example set input"/>
</process>
</operator>
</process>
0 -
Hi Jacob, thanks for your approach. I tried to do this but after editing the XML in the panel view, the Replace input field stays "\n".
Kind regards,
Patrick0 -
Once your change your XML, press the green tick in the left-upped corner of the XML panel. Only then your change will be entered into the process.0
