Hello support team,
I might found a bug in the RegEx implementation of Rapidminer.
My goal is to replace a "blank" with a "new line" character.
Searching in following Text:Sri LankaUsing the Replace operator:
Search for( )
Replace with:\n
leads to:SrinLankaI created a workaround using the "split" operator which you also can see in my sample process.
So the question is: Is it possible to create a new line with RegEx in RM?
<?xml version="1.0" encoding="UTF-8"?><process version="9.7.002">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.7.002" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="text:create_document" compatibility="9.3.001" expanded="true" height="68" name="Create Document" width="90" x="112" y="136">
<parameter key="text" value="Sri Lanka"/>
<parameter key="add label" value="false"/>
<parameter key="label_type" value="nominal"/>
<operator activated="true" class="text:documents_to_data" compatibility="9.3.001" expanded="true" height="82" name="Documents to Data" width="90" x="246" y="136">
<parameter key="text_attribute" value="text"/>
<parameter key="add_meta_information" value="true"/>
<parameter key="datamanagement" value="double_sparse_array"/>
<parameter key="data_management" value="auto"/>
<parameter key="use_processed_text" value="false"/>
<operator activated="true" class="multiply" compatibility="9.7.002" expanded="true" height="103" name="Multiply" width="90" x="447" y="136"/>
<operator activated="true" class="split" compatibility="9.7.002" expanded="true" height="82" name="Split" width="90" x="648" y="289">
<parameter key="attribute_filter_type" value="all"/>
<parameter key="attribute" value=""/>
<parameter key="value_type" value="nominal"/>
<parameter key="except_value_type" value="file_path"/>
<parameter key="block_type" value="single_value"/>
<parameter key="except_block_type" value="single_value"/>
<parameter key="split_pattern" value=" "/>
<parameter key="split_mode" value="ordered_split"/>
<operator activated="true" class="transpose" compatibility="9.7.002" expanded="true" height="82" name="Transpose" width="90" x="782" y="289"/>
<operator activated="true" class="replace" compatibility="9.7.002" expanded="true" height="82" name="Replace" width="90" x="648" y="34">
<parameter key="replace_what" value="( )"/>
<parameter key="replace_by" value="\n"/>
<connect from_op="Create Document" from_port="output" to_op="Documents to Data" to_port="documents 1"/>
<connect from_op="Documents to Data" from_port="example set" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="Replace" to_port="example set input"/>
<connect from_op="Multiply" from_port="output 2" to_op="Split" to_port="example set input"/>
<connect from_op="Split" from_port="example set output" to_op="Transpose" to_port="example set input"/>
<connect from_op="Transpose" from_port="example set output" to_port="result 2"/>
<connect from_op="Replace" from_port="example set output" to_port="result 1"/>
</process>
</process>
Kind Regards,
Patrick
