having both id and labeled attribute in data set
dear all,
While Im generating 'id' for a daset, it overrides or disappears the already labelled attribute. Mine is a classification problem. How to have both? I want to generate id to see which examples are used while go thro the steps of process. Also I need to have labelled attribute for the classification problem. thanks.
regds
thiru
regds
thiru
1 - 2 of
21
MartinLiebig
Hi Thiru,
are you sure your "labelled attribute" is not of role id? If so, please set it to another role first.
~Martin
@schmitz , thanks for your reply.
if i use 'generate id' over the data set with ALREADY labelled attribute, the labelled attribute disappears. After importing
the data set, then set role for label, then 'generate id' - it works. . Not sure why label disappears, if i use the generate id on the dataset imported with label.
