🎉Community Raffle - Win $25
Join and Win
Problem with import of excel file
User: "LeMarc"
New Altair Community Member
Updated by Jocelyn
Hello,
I tried to import data from an excel file. However theres always an error message which says
"Failed to parse the content in column 'sales':
Cause: unpearsable real numbers:"-" "
Within the feature sale there are some values of 0.
Does anyone have a suggestion how to solve?
Thank you!
1 - 5 of 51
    @LeMark,
    Hello
    Could you please take an screenshot from "sales"?
    seems like some of your "numbers" are rather something like 1-2?
    I would recommend to use "read all columns as polynominal" option and parse the numbers later.
    Best,
    Martin
    User: "LeMarc"
    OP
    Hi, problem is solved. I changed the format of column sales. Thanks!
    User: "Telcontar120"
    You may also have missing values or zero value represented by the hyphen "-" in which case you can use declare missing value or replace operator to solve that problem.
    User: "LeMarc"
    OP
    @Telcontar120 Thanks for the hint!
