Altair RISE
Nominate Yourself Now!
Display Correlation and P-Values
User: "fatima_tm"
New Altair Community Member
Updated by Jocelyn
how can I see what are the correlation values,-p-value? and coefficients?
is there a way to see them? so that I know which values are correlated with my model
1 - 2 of 21
    User: "varunm1"
    Accepted Answer
    Hello @fatima_tm
    If you are looking for p-values and coefficients related to logistic regression, they are displayed if you connect the "mod" port of the logistic regression model to results. You also need to select compute p-values in the parameter window of a logistic regression operator.
    Correlation between attributes and your outcome variable by using a correlation matrix operator and select "include special attributes".
    If you are trying to look at statistical significance of different models, you can also use T-test or ANOVA operators.
    If this is not what you are looking for, please provide us with more details.
    User: "fatima_tm"
    OP
    I did both the correlation matrix and connected the "mod" to results and got it
    thank you very much
