🎉Community Raffle - Win $25
Join and Win
Model execution and deployment on server
DivyemUser: "Divyem"
New Altair Community Member
Updated by Jocelyn
I am unable to deploy the model in the rapidminer server. I was testing a simple titanic model deployment to configure it as a web service. Once the deployment was done and everything was set. Post execution of webservice, it gave me an error of unknown operator.
I thought of executing the models in the server itself but they gave me an error again during auto model process itself. Please note I have used mysql connection to rapidminer server and connection was successful.
1 - 5 of 51
    Hi @Divyem ,
    did you use any operator which is part of an extension? If so, please make sure that this extension is also installed on the server.
    Best,
    Martin
    OP
    @mschmitz
    Can you share the document where extensions are present or deployment process for them. I looked but couldn't find.
    I am just deploying a simple deep Learning model prepared on the titanic sample set available. Once deployed running the webservice gives me unknown operator error.
    Simple process operator is itself showing me the error
    Hi,
    WHich opertor is unknown? And what exactly is the error?
    Best,
    Martin
    OP
    Accepted Answer
    @mschmitz I am attaching two images above, These are the recent tries I did post installation of rapid server.
    * The first is post deploying the model into the server and executing the webservice request. The model building was done on studio. Check the response for unknown operator
    * The second image I am trying to execute the auto model on the server itself just to be sure that the operators used are present in the server but I get this error.
    I am trying to create a webservice url to for a sample set.
    OP
    Accepted Answer
    @mschmitz this was resolved with the help of rapid team, there was some license issue for the server thanks
