Model execution and deployment on server
I am unable to deploy the model in the rapidminer server. I was testing a simple titanic model deployment to configure it as a web service. Once the deployment was done and everything was set. Post execution of webservice, it gave me an error of unknown operator.
I thought of executing the models in the server itself but they gave me an error again during auto model process itself. Please note I have used mysql connection to rapidminer server and connection was successful.
1 - 5 of
51
MartinLiebig
Hi @Divyem ,
did you use any operator which is part of an extension? If so, please make sure that this extension is also installed on the server.
Best,
Martin
@mschmitz
Can you share the document where extensions are present or deployment process for them. I looked but couldn't find.
I am just deploying a simple deep Learning model prepared on the titanic sample set available. Once deployed running the webservice gives me unknown operator error.
Simple process operator is itself showing me the error
@mschmitz I am attaching two images above, These are the recent tries I did post installation of rapid server.
* The first is post deploying the model into the server and executing the webservice request. The model building was done on studio. Check the response for unknown operator
* The second image I am trying to execute the auto model on the server itself just to be sure that the operators used are present in the server but I get this error.
I am trying to create a webservice url to for a sample set.
1 - 2 of
21
@mschmitz this was resolved with the help of rapid team, there was some license issue for the server thanks
