🎉Community Raffle - Win $25
Join and Win
rapidminer-batch.sh on mac error
RyandaUser: "Ryanda"
New Altair Community Member
Updated by Jocelyn
Hi, i need some help to fix this. i've searched for possible solution but still getting the same error.
i want to run a process using script in terminal, i opened a terminal from script folder directly and input this code:
sh rapidminer-batch.sh -f /Users/ryanda/Documents/Rapidminer/Alfa/test_write_from_database.rm
and then i got this error message:
<p>RAPIDMINER_HOME is not set. Trying the directory '/Applications/RapidMiner Studio.app/Contents/Resources/RapidMiner-Studio'...</p>
<p>Exception in thread "main" java.lang.NoClassDefFoundError: javax/xml/bind/DatatypeConverter</p>
<p><span>	at com.rapidminer.security.PluginSandboxPolicy.createPublicKey(PluginSandboxPolicy.java:161)</span></p>
<p><span>	at com.rapidminer.security.PluginSandboxPolicy.<clinit>(PluginSandboxPolicy.java:111)</span></p>
<p><span>	at com.rapidminer.launcher.CommandLineLauncher.main(CommandLineLauncher.java:309)</span></p>
<p>Caused by: java.lang.ClassNotFoundException: javax.xml.bind.DatatypeConverter</p>
<p><span>	at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:602)</span></p>
<p><span>	at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(ClassLoaders.java:178)</span></p>
<p><span>	at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:522)</span></p>
<p><span>	... 3 more</span></p>
i found another post saying you need JDK 8 for rapidminer.
my rapidminer is version 9.6 and this is the java version i'm using:
<p>java version "1.8.0_241"</p>
<p>Java(TM) SE Runtime Environment (build 1.8.0_241-b07)</p>
<p>Java HotSpot(TM) 64-Bit Server VM (build 25.241-b07, mixed mode)</p>
Thanks,
1 - 4 of 41
    rfuentealbaUser: "rfuentealba"
    Accepted Answer
    Hello.
    What does the JAVA_HOME environment look like? That might be pointing to another version of Java.
    Perhaps if instead of using sh, you just give permissions to the rapidminer-batch.sh?
    All.the best,
    Rod.
    OP
    Hi thanks for the answer,
    After i check the java environment it was pointing to JDK 14 that i have.
    I changed it to version 1.8 and now the result is this:
    /Library/Java/JavaVirtualMachines/jdk1.8.0_241.jdk/Contents/Home
    Then i tried to run the same command as i post before and it show me this:
    RapidMiner Studio version 9.6.000, Copyright (C) 2001-2020 RapidMiner GmbH
    See End User License Agreement information in the file named EULA.
    Apr 14, 2020 7:59:36 PM com.rapidminer.tools.I18N <clinit>
    INFO: Set locale to en.
    Apr 14, 2020 7:59:36 PM com.rapidminer.tools.PlatformUtilities logInfo
    INFO: rapidminer.home is '/Applications/RapidMiner Studio.app/Contents/Resources/RapidMiner-Studio'.
    Apr 14, 2020 7:59:36 PM com.rapidminer.core.license.ProductConstraintManager initialize
    INFO: Initializing license manager.
    INFO: Using default license location.
    INFO: Registering default product.
    Apr 14, 2020 7:59:39 PM com.rapidminer.tools.plugin.Plugin registerPlugins
    INFO: Register plugin: Converters
    INFO: Register plugin: In-Database Processing
    INFO: Register plugin: Python Scripting
    INFO: Register plugin: Text Processing
    INFO: Register plugin: Blending
    INFO: Register plugin: Process Scheduling
    INFO: Register plugin: Cloud Connectivity
    INFO: Register plugin: Advanced File Connectors
    INFO: Register plugin: Legacy Result Access
    INFO: Register plugin: Concurrency
    INFO: Register plugin: HTML5 Charts
    INFO: Register plugin: Model Deployment Management
    INFO: Register plugin: Time Series
    INFO: Register plugin: Remote Repository
    INFO: Register plugin: Browser
    INFO: Register plugin: Utility
    INFO: Register plugin: Professional
    INFO: Register plugin: Model Simulator
    INFO: Register plugin: CTA
    INFO: Register plugin: H2O
    INFO: Register plugin: Data Editor
    INFO: Register plugin: Productivity
    INFO: Register plugin: Social Media
    INFO: Register plugin: Operator Recommender
    INFO: Register plugin: JDBC Connectors
    Apr 14, 2020 7:59:40 PM com.rapidminer.tools.config.ConfigurationManager register
    INFO: Registered configurator Twitter Connection.
    Apr 14, 2020 7:59:41 PM com.rapidminer.tools.config.ConfigurationManager register
    INFO: Registered configurator Salesforce Connection.
    INFO: Registered configurator Amazon S3 Connection.
    INFO: Registered configurator Azure Blob Storage Connection.
    INFO: Registered configurator Azure Data Lake Storage Gen1 Connection.
    INFO: Registered configurator Google Cloud Storage Connection.
    INFO: Registered configurator Dropbox Connection.
    Apr 14, 2020 7:59:43 PM com.rapidminer.extension.jdbc.tools.jdbc.JDBCProperties <init>
    WARNING: Missing database driver class name for ODBC Bridge (e.g. Access)
    WARNING: Missing database driver class name for Ingres
    Apr 14, 2020 7:59:45 PM com.rapidminer.repository.RepositoryManager registerExtensionSamples
    INFO: Registered 'Time Series' as sample folder.
    Apr 14, 2020 7:59:45 PM com.rapidminer.extension.jdbc.tools.jdbc.JDBCProperties <init>
    Apr 14, 2020 7:59:46 PM com.rapidminer.extension.indatabase.provider.DatabaseProviderFactory registerProvider
    INFO: Registered database provider: GoogleBigQueryProvider
    INFO: Registered database provider: MySQLProvider
    INFO: Registered database provider: PostgreSQLProvider
    INFO: Registered database provider: EmbeddedProvider
    INFO: Registered database provider: GenericProvider
    Apr 14, 2020 7:59:46 PM com.rapidminer.tools.config.ConfigurationManager register
    INFO: Registered configurator Google BigQuery Connection.
    Apr 14, 2020 7:59:46 PM com.rapidminer.tools.plugin.Plugin initAll
    INFO: Extension Converters was loaded in 8ms.
    INFO: Extension Text Processing was loaded in 77ms.
    INFO: Extension Blending was loaded in 122ms.
    INFO: Extension Utility was loaded in 123ms.
    INFO: Extension Python Scripting was loaded in 132ms.
    INFO: Extension Process Scheduling was loaded in 141ms.
    INFO: Extension Data Editor was loaded in 153ms.
    INFO: Extension Model Deployment Management was loaded in 158ms.
    INFO: Extension Professional was loaded in 167ms.
    INFO: Extension Productivity was loaded in 172ms.
    INFO: Extension CTA was loaded in 175ms.
    INFO: Extension Advanced File Connectors was loaded in 203ms.
    INFO: Extension In-Database Processing was loaded in 207ms.
    INFO: Extension Operator Recommender was loaded in 221ms.
    INFO: Extension HTML5 Charts was loaded in 251ms.
    INFO: Extension Social Media was loaded in 252ms.
    INFO: Extension Browser was loaded in 289ms.
    INFO: Extension Concurrency was loaded in 325ms.
    INFO: Extension Remote Repository was loaded in 325ms.
    INFO: Extension Time Series was loaded in 370ms.
    INFO: Extension Model Simulator was loaded in 382ms.
    INFO: Extension Legacy Result Access was loaded in 419ms.
    INFO: Extension H2O was loaded in 499ms.
    INFO: Extension Cloud Connectivity was loaded in 645ms.
    INFO: Extension JDBC Connectors was loaded in 926ms.
    Apr 14, 2020 8:00:02 PM com.rapidminer.extension.timeseries.operator.basetransformation.equalize.AbstractEqualizeTimeSeriesOperator getAdditionalParameterTypes
    WARNING: No operator description object given for 'com.rapidminer.extension.timeseries.operator.transformation.ReplaceMissingValuesOperator'
    Apr 14, 2020 8:00:02 PM com.rapidminer.tools.config.ConfigurationManager loadConfiguration
    INFO: Load configuration for Amazon S3 Connection.
    Apr 14, 2020 8:00:02 PM com.rapidminer.tools.config.ClientConfigurationManager loadAllParameters
    INFO: No configuration file found for Amazon S3 Connection
    INFO: Loaded configurations for 0 objects of type Amazon S3 Connection.
    INFO: Load configuration for Azure Blob Storage Connection.
    INFO: No configuration file found for Azure Blob Storage Connection
    INFO: Loaded configurations for 0 objects of type Azure Blob Storage Connection.
    INFO: Load configuration for Azure Data Lake Storage Gen1 Connection.
    INFO: No configuration file found for Azure Data Lake Storage Gen1 Connection
    INFO: Loaded configurations for 0 objects of type Azure Data Lake Storage Gen1 Connection.
    INFO: Load configuration for Dropbox Connection.
    INFO: No configuration file found for Dropbox Connection
    INFO: Loaded configurations for 0 objects of type Dropbox Connection.
    INFO: Load configuration for Salesforce Connection.
    INFO: No configuration file found for Salesforce Connection
    INFO: Loaded configurations for 0 objects of type Salesforce Connection.
    INFO: Load configuration for Google BigQuery Connection.
    INFO: No configuration file found for Google BigQuery Connection
    INFO: Loaded configurations for 0 objects of type Google BigQuery Connection.
    INFO: Load configuration for Google Cloud Storage Connection.
    INFO: No configuration file found for Google Cloud Storage Connection
    INFO: Loaded configurations for 0 objects of type Google Cloud Storage Connection.
    INFO: Load configuration for Twitter Connection.
    INFO: No configuration file found for Twitter Connection
    INFO: Loaded configurations for 0 objects of type Twitter Connection.
    Apr 14, 2020 8:00:05 PM com.rapidminer.tools.ResultService init
    INFO: No filename given for result file, using stdout for logging results!
    Apr 14, 2020 8:00:05 PM com.rapidminer.Process execute
    INFO: Process /Users/ryanda/Documents/Rapidminer/Alfa/test_write_from_database.rmp starts
    Apr 14, 2020 8:00:08 PM com.rapidminer.launcher.CommandLineLauncher runProcessAndQuit
    SEVERE: Process failed: Database error occurred: Could not connect to address=(host=reportdb.alfatrex.id)(port=3306)(type=master) : Socket fail to connect to host:reportdb.alfatrex.id, port:3306. reportdb.alfatrex.id
    com.rapidminer.operator.UserError: Database error occurred: Could not connect to address=(host=reportdb.alfatrex.id)(port=3306)(type=master) : Socket fail to connect to host:reportdb.alfatrex.id, port:3306. reportdb.alfatrex.id
    at com.rapidminer.extension.jdbc.operator.io.DatabaseDataReader.getResultSet(DatabaseDataReader.java:127)
    at com.rapidminer.extension.jdbc.operator.io.DatabaseDataReader.createExampleSet(DatabaseDataReader.java:134)
    at com.rapidminer.operator.io.AbstractExampleSource.read(AbstractExampleSource.java:53)
    at com.rapidminer.extension.jdbc.operator.io.DatabaseDataReader.read(DatabaseDataReader.java:101)
    at com.rapidminer.extension.jdbc.operator.io.DatabaseDataReader.read(DatabaseDataReader.java:82)
    at com.rapidminer.operator.io.AbstractReader.doWork(AbstractReader.java:271)
    at com.rapidminer.operator.Operator.execute(Operator.java:1032)
    at com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:77)
    at com.rapidminer.operator.ExecutionUnit$2.run(ExecutionUnit.java:812)
    at com.rapidminer.operator.ExecutionUnit$2.run(ExecutionUnit.java:807)
    at java.security.AccessController.doPrivileged(Native Method)
    at com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:807)
    at com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:423)
    at com.rapidminer.Process.executeRoot(Process.java:1379)
    at com.rapidminer.Process.lambda$executeRootInPool$5(Process.java:1358)
    at com.rapidminer.studio.concurrency.internal.AbstractConcurrencyContext$AdaptedCallable.exec(AbstractConcurrencyContext.java:328)
    at java.util.concurrent.ForkJoinTask.doExec(ForkJoinTask.java:289)
    at java.util.concurrent.ForkJoinPool$WorkQueue.runTask(ForkJoinPool.java:1056)
    at java.util.concurrent.ForkJoinPool.runWorker(ForkJoinPool.java:1692)
    at java.util.concurrent.ForkJoinWorkerThread.run(ForkJoinWorkerThread.java:157)
    Caused by: java.sql.SQLNonTransientConnectionException: Could not connect to address=(host=reportdb.alfatrex.id)(port=3306)(type=master) : Socket fail to connect to host:reportdb.alfatrex.id, port:3306. reportdb.alfatrex.id
    at org.mariadb.jdbc.internal.util.exceptions.ExceptionMapper.get(ExceptionMapper.java:241)
    at org.mariadb.jdbc.internal.protocol.AbstractConnectProtocol.connectWithoutProxy(AbstractConnectProtocol.java:1241)
    at org.mariadb.jdbc.internal.util.Utils.retrieveProxy(Utils.java:610)
    at org.mariadb.jdbc.MariaDbConnection.newConnection(MariaDbConnection.java:142)
    at org.mariadb.jdbc.Driver.connect(Driver.java:86)
    at com.rapidminer.extension.jdbc.tools.jdbc.DriverAdapter.connect(DriverAdapter.java:51)
    at com.rapidminer.extension.jdbc.connection.JDBCConnectionHandler.connect(JDBCConnectionHandler.java:266)
    at com.rapidminer.extension.jdbc.tools.jdbc.DatabaseHandler.connect(DatabaseHandler.java:423)
    at com.rapidminer.extension.jdbc.tools.jdbc.DatabaseHandler.getConnectedDatabaseHandler(DatabaseHandler.java:305)
    at com.rapidminer.extension.jdbc.tools.jdbc.DatabaseHandler.getConnectedDatabaseHandler(DatabaseHandler.java:1204)
    at com.rapidminer.extension.jdbc.operator.io.DatabaseDataReader.getResultSet(DatabaseDataReader.java:115)
    ... 20 more
    Caused by: java.sql.SQLNonTransientConnectionException: Socket fail to connect to host:reportdb.alfatrex.id, port:3306. reportdb.alfatrex.id
    at org.mariadb.jdbc.internal.util.exceptions.ExceptionMapper.connException(ExceptionMapper.java:87)
    at org.mariadb.jdbc.internal.protocol.AbstractConnectProtocol.createSocket(AbstractConnectProtocol.java:218)
    at org.mariadb.jdbc.internal.protocol.AbstractConnectProtocol.createConnection(AbstractConnectProtocol.java:474)
    at org.mariadb.jdbc.internal.protocol.AbstractConnectProtocol.connectWithoutProxy(AbstractConnectProtocol.java:1236)
    ... 29 more
    Caused by: java.net.UnknownHostException: reportdb.alfatrex.id
    at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:184)
    at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
    at java.net.Socket.connect(Socket.java:606)
    at org.mariadb.jdbc.internal.protocol.AbstractConnectProtocol.createSocket(AbstractConnectProtocol.java:213)
    ... 31 more
    SEVERE: Here:           Process[1] (Process)
               subprocess 'Main Process'
                 +- Retrieve reportdb[1] (Retrieve)
           ==>   +- Read Database[1] (Read Database)
                 +- Write Excel[0] (Write Excel)
    SEVERE: Process not successful
    At first it says "
    RAPIDMINER_HOME is not set." but in the end it says "SEVERE: Process not successful".
    Does it mean it fixed my java problem?
    Because i haven't tried with shorter process yet so i'm not sure about it.
    Thanks,
    Yes, you did.
    You can now check with a shorter process such as writing a dataset on disk or modify paths.
    Actually your problem is that your process couldn't connect to MySQL, apparently.
    OP
    it works just fine now.
    thank you so much for the help.
