Remove correlated features from training set and apply the same features to test set
Hello all,
I just wondering how you achieve to remove pairwise correlated features from your training set (using the Remove Correlated Attributes operator) and apply the same features to your test set? If I should compare this operation to something I think about the "Apply feature set" (as exists for the features selection operator) or somewhat OHE and the Preprocessing model output. See screenshot below of the process. I have normally these two training and test preprocessing operations in two different processes.
Thanks for your help.
1 - 3 of
31
Hi @Andy3,
you usually don't need to do it. Keep in mind that Apply Model is ignoring additional attributes.
Best,
Martin
Hi @Andy3 ,
if you need to do it, you can use Data to Weights for it. Attached is an example.
BR,
Martin
<?xml version="1.0" encoding="UTF-8"?><process version="9.6.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.6.000" expanded="true" name="Process">
<parameter key="logverbosity" value="init"/>
<parameter key="random_seed" value="2001"/>
<parameter key="send_mail" value="never"/>
<parameter key="notification_email" value=""/>
<parameter key="process_duration_for_mail" value="30"/>
<parameter key="encoding" value="SYSTEM"/>
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="9.6.000" expanded="true" height="68" name="Retrieve Sonar" width="90" x="45" y="34">
<parameter key="repository_entry" value="//Samples/data/Sonar"/>
</operator>
<operator activated="true" class="select_attributes" compatibility="9.6.000" expanded="true" height="82" name="Select Attributes" width="90" x="179" y="34">
<parameter key="attribute_filter_type" value="single"/>
<parameter key="attribute" value="attribute_1"/>
<parameter key="attributes" value=""/>
<parameter key="use_except_expression" value="false"/>
<parameter key="value_type" value="attribute_value"/>
<parameter key="use_value_type_exception" value="false"/>
<parameter key="except_value_type" value="time"/>
<parameter key="block_type" value="attribute_block"/>
<parameter key="use_block_type_exception" value="false"/>
<parameter key="except_block_type" value="value_matrix_row_start"/>
<parameter key="invert_selection" value="false"/>
<parameter key="include_special_attributes" value="false"/>
</operator>
<operator activated="true" class="data_to_weights" compatibility="9.6.000" expanded="true" height="82" name="Data to Weights" width="90" x="313" y="34">
<parameter key="normalize_weights" value="false"/>
<parameter key="sort_weights" value="true"/>
<parameter key="sort_direction" value="ascending"/>
</operator>
<operator activated="true" class="retrieve" compatibility="9.6.000" expanded="true" height="68" name="Retrieve Sonar (2)" width="90" x="45" y="238">
</operator>
<operator activated="true" class="select_by_weights" compatibility="9.6.000" expanded="true" height="103" name="Select by Weights" width="90" x="514" y="136">
<parameter key="weight_relation" value="greater equals"/>
<parameter key="weight" value="1.0"/>
<parameter key="k" value="10"/>
<parameter key="p" value="0.5"/>
<parameter key="deselect_unknown" value="true"/>
<parameter key="use_absolute_weights" value="true"/>
</operator>
<connect from_op="Retrieve Sonar" from_port="output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Data to Weights" to_port="example set"/>
<connect from_op="Data to Weights" from_port="weights" to_op="Select by Weights" to_port="weights"/>
<connect from_op="Retrieve Sonar (2)" from_port="output" to_op="Select by Weights" to_port="example set input"/>
<connect from_op="Select by Weights" from_port="example set output" to_port="result 1"/>
</process>
</operator>
</process>
<context>
<input/>
<output/>
<macros/>
</context>
</operator>
</operator>
</operator>
</operator>
</operator>
</process>
</operator>
</process>
1 - 2 of
21
Hi @Andy3,
Best,
Martin
Hi @Andy3 ,
BR,
Martin
<context>
<input/>
<output/>
<macros/>
</context>
</operator>
</operator>
</operator>
</operator>
</operator>
</process>
</operator>
</process>
<context>
<input/>
<output/>
<macros/>
</context>
</operator>
</operator>
</operator>
</operator>
</operator>
</process>
</operator>
</process>
