Altair RISE
Nominate Yourself Now!
Remove correlated features from training set and apply the same features to test set
Andy3
Hello all,
I just wondering how you achieve to remove pairwise correlated features from your training set (using the Remove Correlated Attributes operator) and apply the same features to your test set? If I should compare this operation to something I think about the "Apply feature set" (as exists for the features selection operator) or somewhat OHE and the Preprocessing model output. See screenshot below of the process. I have normally these two training and test preprocessing operations in two different processes.
Thanks for your help.
Correlation
MartinLiebig
Hi
@Andy3
you usually don't need to do it. Keep in mind that Apply Model is ignoring additional attributes.
Best,
Martin
MartinLiebig
Hi
@Andy3
if you need to do it, you can use Data to Weights for it. Attached is an example.
BR,
Martin
<?xml version="1.0" encoding="UTF-8"?><process version="9.6.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.6.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="9.6.000" expanded="true" height="68" name="Retrieve Sonar" width="90" x="45" y="34">
<parameter key="repository_entry" value="//Samples/data/Sonar"/>
<operator activated="true" class="select_attributes" compatibility="9.6.000" expanded="true" height="82" name="Select Attributes" width="90" x="179" y="34">
<parameter key="attribute" value="attribute_1"/>
<operator activated="true" class="data_to_weights" compatibility="9.6.000" expanded="true" height="82" name="Data to Weights" width="90" x="313" y="34">
<parameter key="normalize_weights" value="false"/>
<parameter key="sort_weights" value="true"/>
<parameter key="sort_direction" value="ascending"/>
<operator activated="true" class="retrieve" compatibility="9.6.000" expanded="true" height="68" name="Retrieve Sonar (2)" width="90" x="45" y="238">
<operator activated="true" class="select_by_weights" compatibility="9.6.000" expanded="true" height="103" name="Select by Weights" width="90" x="514" y="136">
<parameter key="weight_relation" value="greater equals"/>
<parameter key="weight" value="1.0"/>
<parameter key="k" value="10"/>
<parameter key="p" value="0.5"/>
<parameter key="deselect_unknown" value="true"/>
<parameter key="use_absolute_weights" value="true"/>
<connect from_op="Retrieve Sonar" from_port="output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Data to Weights" to_port="example set"/>
<connect from_op="Data to Weights" from_port="weights" to_op="Select by Weights" to_port="weights"/>
<connect from_op="Retrieve Sonar (2)" from_port="output" to_op="Select by Weights" to_port="example set input"/>
<connect from_op="Select by Weights" from_port="example set output" to_port="result 1"/>
</process>
</process>
MartinLiebig
Hi
@Andy3
Best,
Martin
Andy3
Yeah, fair enough though I was hoping the where an operator(s) like this so I could have consistency through the various data sets (and in my mind
). I leave it there.
Thanks for the help.
MartinLiebig
Hi
@Andy3
BR,
Martin
<context>
<input/>
<output/>
<macros/>
</context>
</process>
</process>
