🎉Community Raffle - Win $25
Join and Win
How to pass macro value in generate id offset for start the sequence
User: "sgnarkhede2016"
New Altair Community Member
Updated by Jocelyn
1 - 1 of 11
    User: "MartinLiebig"
    Altair Employee
    Accepted Answer
    Hi,
    see attached example.
    BR,
    Martin
    <?xml version="1.0" encoding="UTF-8"?><process version="9.6.000">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="9.6.000" expanded="true" name="Process">
        <parameter key="logverbosity" value="init"/>
        <parameter key="random_seed" value="2001"/>
        <parameter key="send_mail" value="never"/>
        <parameter key="notification_email" value=""/>
        <parameter key="process_duration_for_mail" value="30"/>
        <parameter key="encoding" value="SYSTEM"/>
        <process expanded="true">
          <operator activated="true" class="generate_data" compatibility="9.6.000" expanded="true" height="68" name="Generate Data" width="90" x="45" y="85">
            <parameter key="target_function" value="random"/>
            <parameter key="number_examples" value="100"/>
            <parameter key="number_of_attributes" value="5"/>
            <parameter key="attributes_lower_bound" value="-10.0"/>
            <parameter key="attributes_upper_bound" value="10.0"/>
            <parameter key="gaussian_standard_deviation" value="10.0"/>
            <parameter key="largest_radius" value="10.0"/>
            <parameter key="use_local_random_seed" value="false"/>
            <parameter key="local_random_seed" value="1992"/>
            <parameter key="datamanagement" value="double_array"/>
            <parameter key="data_management" value="auto"/>
          </operator>
          <operator activated="true" class="set_macro" compatibility="9.6.000" expanded="true" height="82" name="Set Macro" width="90" x="179" y="85">
            <parameter key="macro" value="myMacro"/>
            <parameter key="value" value="5"/>
          </operator>
          <operator activated="true" class="generate_id" compatibility="9.6.000" expanded="true" height="82" name="Generate ID" width="90" x="313" y="85">
            <parameter key="create_nominal_ids" value="false"/>
            <parameter key="offset" value="%{myMacro}"/>
          </operator>
          <connect from_op="Generate Data" from_port="output" to_op="Set Macro" to_port="through 1"/>
          <connect from_op="Set Macro" from_port="through 1" to_op="Generate ID" to_port="example set input"/>
          <connect from_op="Generate ID" from_port="example set output" to_port="result 1"/>
        </process>
      </operator>
    </process>
