<?xml version="1.0" encoding="UTF-8"?><process version="9.6.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.6.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="-1"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="read_excel" compatibility="9.6.000" expanded="true" height="68" name="Read Excel" width="90" x="45" y="34"> <parameter key="excel_file" value="/Users/scottgenzer-rapidminercommunity/Downloads/KPI Examples.xlsx"/> <parameter key="sheet_selection" value="sheet number"/> <parameter key="sheet_number" value="1"/> <parameter key="imported_cell_range" value="A1"/> <parameter key="encoding" value="SYSTEM"/> <parameter key="first_row_as_names" value="true"/> <list key="annotations"/> <parameter key="date_format" value=""/> <parameter key="time_zone" value="America/New_York"/> <parameter key="locale" value="English (United States)"/> <parameter key="read_all_values_as_polynominal" value="false"/> <list key="data_set_meta_data_information"> <parameter key="0" value="Brand.true.polynominal.attribute"/> <parameter key="1" value="Country.true.polynominal.attribute"/> <parameter key="2" value="Region.true.polynominal.attribute"/> <parameter key="3" value="Market.true.integer.attribute"/> <parameter key="4" value="Data_Year.true.integer.attribute"/> <parameter key="5" value="Data_Month.true.polynominal.attribute"/> <parameter key="6" value="Dealer_ID.true.polynominal.attribute"/> <parameter key="7" value="Data_Point.true.polynominal.attribute"/> <parameter key="8" value="KPI.true.polynominal.attribute"/> <parameter key="9" value="Data.true.real.attribute"/> <parameter key="10" value="Rank.true.integer.attribute"/> <parameter key="11" value="Value.true.real.attribute"/> <parameter key="12" value="Report Month.true.polynominal.attribute"/> </list> <parameter key="read_not_matching_values_as_missings" value="false"/> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> </operator> <operator activated="true" class="concurrency:loop_values" compatibility="9.6.000" expanded="true" height="82" name="Loop Values" width="90" x="179" y="34"> <parameter key="attribute" value="Dealer_ID"/> <parameter key="iteration_macro" value="loop_value"/> <parameter key="reuse_results" value="false"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="filter_examples" compatibility="9.6.000" expanded="true" height="103" name="Filter Examples" width="90" x="45" y="34"> <parameter key="parameter_expression" value=""/> <parameter key="condition_class" value="custom_filters"/> <parameter key="invert_filter" value="false"/> <list key="filters_list"> <parameter key="filters_entry_key" value="Dealer_ID.equals.%{loop_value}"/> </list> <parameter key="filters_logic_and" value="true"/> <parameter key="filters_check_metadata" value="true"/> </operator> <operator activated="true" class="write_excel" compatibility="9.6.000" expanded="true" height="103" name="Write Excel" width="90" x="179" y="34"> <parameter key="excel_file" value="DealerID%{loop_value}"/> <parameter key="file_format" value="xlsx"/> <enumeration key="sheet_names"/> <parameter key="sheet_name" value="RapidMiner Data"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="number_format" value="#.0"/> <parameter key="encoding" value="SYSTEM"/> </operator> <connect from_port="input 1" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Write Excel" to_port="input"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> </process> </operator> <connect from_op="Read Excel" from_port="output" to_op="Loop Values" to_port="input 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator> </process>
<?xml version="1.0" encoding="UTF-8"?><process version="9.6.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.6.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="-1"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="read_excel" compatibility="9.6.000" expanded="true" height="68" name="Read Excel" width="90" x="45" y="34"> <parameter key="excel_file" value="/Users/scottgenzer-rapidminercommunity/Downloads/KPI Examples.xlsx"/> <parameter key="sheet_selection" value="sheet number"/> <parameter key="sheet_number" value="1"/> <parameter key="imported_cell_range" value="A1"/> <parameter key="encoding" value="SYSTEM"/> <parameter key="first_row_as_names" value="true"/> <list key="annotations"/> <parameter key="date_format" value=""/> <parameter key="time_zone" value="America/New_York"/> <parameter key="locale" value="English (United States)"/> <parameter key="read_all_values_as_polynominal" value="false"/> <list key="data_set_meta_data_information"> <parameter key="0" value="Brand.true.polynominal.attribute"/> <parameter key="1" value="Country.true.polynominal.attribute"/> <parameter key="2" value="Region.true.polynominal.attribute"/> <parameter key="3" value="Market.true.integer.attribute"/> <parameter key="4" value="Data_Year.true.integer.attribute"/> <parameter key="5" value="Data_Month.true.polynominal.attribute"/> <parameter key="6" value="Dealer_ID.true.polynominal.attribute"/> <parameter key="7" value="Data_Point.true.polynominal.attribute"/> <parameter key="8" value="KPI.true.polynominal.attribute"/> <parameter key="9" value="Data.true.real.attribute"/> <parameter key="10" value="Rank.true.integer.attribute"/> <parameter key="11" value="Value.true.real.attribute"/> <parameter key="12" value="Report Month.true.polynominal.attribute"/> </list> <parameter key="read_not_matching_values_as_missings" value="false"/> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> </operator> <operator activated="true" class="concurrency:loop_values" compatibility="9.6.000" expanded="true" height="82" name="Loop Values" width="90" x="179" y="34"> <parameter key="attribute" value="Dealer_ID"/> <parameter key="iteration_macro" value="loop_value"/> <parameter key="reuse_results" value="false"/> <parameter key="enable_parallel_execution" value="false"/> <process expanded="true"> <operator activated="true" class="filter_examples" compatibility="9.6.000" expanded="true" height="103" name="Filter Examples" width="90" x="45" y="34"> <parameter key="parameter_expression" value=""/> <parameter key="condition_class" value="custom_filters"/> <parameter key="invert_filter" value="false"/> <list key="filters_list"> <parameter key="filters_entry_key" value="Dealer_ID.equals.%{loop_value}"/> </list> <parameter key="filters_logic_and" value="true"/> <parameter key="filters_check_metadata" value="true"/> </operator> <operator activated="true" class="write_excel" compatibility="9.6.000" expanded="true" height="103" name="Write Excel" width="90" x="179" y="34"> <parameter key="excel_file" value="/Users/scottgenzer-rapidminercommunity/Desktop/DealerID%{loop_value}.xlsx"/> <parameter key="file_format" value="xlsx"/> <enumeration key="sheet_names"/> <parameter key="sheet_name" value="RapidMiner Data"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="number_format" value="#.0"/> <parameter key="encoding" value="SYSTEM"/> </operator> <connect from_port="input 1" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Write Excel" to_port="input"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> </process> </operator> <connect from_op="Read Excel" from_port="output" to_op="Loop Values" to_port="input 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator> </process>
<?xml version="1.0" encoding="UTF-8"?><process version="9.6.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.6.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="-1"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="9.6.000" expanded="true" height="68" name="Retrieve Iris" width="90" x="45" y="34"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="loop_examples" compatibility="9.6.000" expanded="true" height="82" name="Loop Examples" width="90" x="179" y="34"> <parameter key="iteration_macro" value="example"/> <process expanded="true"> <operator activated="true" class="filter_example_range" compatibility="9.6.000" expanded="true" height="82" name="Filter Example Range" width="90" x="45" y="34"> <parameter key="first_example" value="%{example}"/> <parameter key="last_example" value="%{example}"/> <parameter key="invert_filter" value="false"/> </operator> <operator activated="true" class="write_excel" compatibility="9.6.000" expanded="true" height="103" name="Write Excel" width="90" x="179" y="34"> <parameter key="excel_file" value="ROW%{example}"/> <parameter key="file_format" value="xlsx"/> <enumeration key="sheet_names"/> <parameter key="sheet_name" value="RapidMiner Data"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="number_format" value="#.0"/> <parameter key="encoding" value="SYSTEM"/> </operator> <connect from_port="example set" to_op="Filter Example Range" to_port="example set input"/> <connect from_op="Filter Example Range" from_port="example set output" to_op="Write Excel" to_port="input"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> </process> </operator> <connect from_op="Retrieve Iris" from_port="output" to_op="Loop Examples" to_port="example set"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator> </process>
