Altair RISE
Nominate Yourself Now!
Send Example Set to Excel files based on Unique ID
User: "miked"
New Altair Community Member
Updated by Jocelyn
Hi All,
  I'm hoping to once again reach out to the Rapidminer community which has been so helpful. I have created a process where my end result is about 2000 rows which all have a unique ID associated with them. What I'd like to do is be able to write an excel file for each of these unique ID's. Specifically - loop over the process and based on a client ID...create an excel document that only show's that client's data. Excel or PDF would work. Thanks for any help.
1 - 6 of 61
    User: "sgenzer"
    Altair Employee
    hi @miked - I'd just do a Loop Examples and a Filter Example Range inside that filters for only that row. Like this:
    <?xml version="1.0" encoding="UTF-8"?><process version="9.6.000">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="9.6.000" expanded="true" name="Process">
        <parameter key="logverbosity" value="init"/>
        <parameter key="random_seed" value="-1"/>
        <parameter key="send_mail" value="never"/>
        <parameter key="notification_email" value=""/>
        <parameter key="process_duration_for_mail" value="30"/>
        <parameter key="encoding" value="SYSTEM"/>
        <process expanded="true">
          <operator activated="true" class="retrieve" compatibility="9.6.000" expanded="true" height="68" name="Retrieve Iris" width="90" x="45" y="34">
            <parameter key="repository_entry" value="//Samples/data/Iris"/>
          </operator>
          <operator activated="true" class="loop_examples" compatibility="9.6.000" expanded="true" height="82" name="Loop Examples" width="90" x="179" y="34">
            <parameter key="iteration_macro" value="example"/>
              <operator activated="true" class="filter_example_range" compatibility="9.6.000" expanded="true" height="82" name="Filter Example Range" width="90" x="45" y="34">
                <parameter key="first_example" value="%{example}"/>
                <parameter key="last_example" value="%{example}"/>
                <parameter key="invert_filter" value="false"/>
              </operator>
              <operator activated="true" class="write_excel" compatibility="9.6.000" expanded="true" height="103" name="Write Excel" width="90" x="179" y="34">
                <parameter key="excel_file" value="ROW%{example}"/>
                <parameter key="file_format" value="xlsx"/>
                <enumeration key="sheet_names"/>
                <parameter key="sheet_name" value="RapidMiner Data"/>
                <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/>
                <parameter key="number_format" value="#.0"/>
              </operator>
              <connect from_port="example set" to_op="Filter Example Range" to_port="example set input"/>
              <connect from_op="Filter Example Range" from_port="example set output" to_op="Write Excel" to_port="input"/>
              <portSpacing port="source_example set" spacing="0"/>
              <portSpacing port="sink_example set" spacing="0"/>
              <portSpacing port="sink_output 1" spacing="0"/>
            </process>
          </operator>
          <connect from_op="Retrieve Iris" from_port="output" to_op="Loop Examples" to_port="example set"/>
        </process>
      </operator>
    </process>
    Scott
    User: "miked"
    OP
    Hi Scott,
       That is a big help..thank you. I realize I should've been a bit more clear on what I needed to do so apologies for that. I've attached a sample set of data. Basically each "Dealer_ID" has a set of let's say 4 KPI's. I'd like to be able to have an excel file for each Dealer ID that contains their KPI's.
    User: "sgenzer"
    Altair Employee
    Accepted Answer
    ah ok no problem @miked - very similar to what I did before:
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
          <operator activated="true" class="read_excel" compatibility="9.6.000" expanded="true" height="68" name="Read Excel" width="90" x="45" y="34">
            <parameter key="excel_file" value="/Users/scottgenzer-rapidminercommunity/Downloads/KPI Examples.xlsx"/>
            <parameter key="sheet_selection" value="sheet number"/>
            <parameter key="sheet_number" value="1"/>
            <parameter key="imported_cell_range" value="A1"/>
            <parameter key="first_row_as_names" value="true"/>
            <list key="annotations"/>
            <parameter key="date_format" value=""/>
            <parameter key="time_zone" value="America/New_York"/>
            <parameter key="locale" value="English (United States)"/>
            <parameter key="read_all_values_as_polynominal" value="false"/>
            <list key="data_set_meta_data_information">
              <parameter key="0" value="Brand.true.polynominal.attribute"/>
              <parameter key="1" value="Country.true.polynominal.attribute"/>
              <parameter key="2" value="Region.true.polynominal.attribute"/>
              <parameter key="3" value="Market.true.integer.attribute"/>
              <parameter key="4" value="Data_Year.true.integer.attribute"/>
              <parameter key="5" value="Data_Month.true.polynominal.attribute"/>
              <parameter key="6" value="Dealer_ID.true.polynominal.attribute"/>
              <parameter key="7" value="Data_Point.true.polynominal.attribute"/>
              <parameter key="8" value="KPI.true.polynominal.attribute"/>
              <parameter key="9" value="Data.true.real.attribute"/>
              <parameter key="10" value="Rank.true.integer.attribute"/>
              <parameter key="11" value="Value.true.real.attribute"/>
              <parameter key="12" value="Report Month.true.polynominal.attribute"/>
            </list>
            <parameter key="read_not_matching_values_as_missings" value="false"/>
            <parameter key="datamanagement" value="double_array"/>
            <parameter key="data_management" value="auto"/>
          </operator>
          <operator activated="true" class="concurrency:loop_values" compatibility="9.6.000" expanded="true" height="82" name="Loop Values" width="90" x="179" y="34">
            <parameter key="attribute" value="Dealer_ID"/>
            <parameter key="iteration_macro" value="loop_value"/>
            <parameter key="reuse_results" value="false"/>
            <parameter key="enable_parallel_execution" value="true"/>
              <operator activated="true" class="filter_examples" compatibility="9.6.000" expanded="true" height="103" name="Filter Examples" width="90" x="45" y="34">
                <parameter key="parameter_expression" value=""/>
                <parameter key="condition_class" value="custom_filters"/>
                <list key="filters_list">
                  <parameter key="filters_entry_key" value="Dealer_ID.equals.%{loop_value}"/>
                </list>
                <parameter key="filters_logic_and" value="true"/>
                <parameter key="filters_check_metadata" value="true"/>
              </operator>
                <parameter key="excel_file" value="DealerID%{loop_value}"/>
              </operator>
              <connect from_port="input 1" to_op="Filter Examples" to_port="example set input"/>
              <connect from_op="Filter Examples" from_port="example set output" to_op="Write Excel" to_port="input"/>
              <portSpacing port="source_input 2" spacing="0"/>
            </process>
          </operator>
          <connect from_op="Read Excel" from_port="output" to_op="Loop Values" to_port="input 1"/>
        </process>
      </operator>
    </process>
    Scott
    User: "miked"
    OP
    Hi Scott,
     That's awesome..thanks so much! I see this then puts everything into a collection ...am I then able to write to multiple excel files from there? Right now only one Excel file is being generated. Still a newbie so any help is appreciated. Thanks
    -Mike
    User: "sgenzer"
    Altair Employee
    Accepted Answer
    ok got a wacky Java error when I ran it (goodness knows why) but if I turn off parallelization, it writes new Excel sheets for each dealer on my desktop.
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
            </list>
          </operator>
            <parameter key="enable_parallel_execution" value="false"/>
                </list>
              </operator>
                <parameter key="excel_file" value="/Users/scottgenzer-rapidminercommunity/Desktop/DealerID%{loop_value}.xlsx"/>
              </operator>
            </process>
          </operator>
        </process>
      </operator>
    </process>
    Scott
    User: "miked"
    OP
    @sgenzer
    That did the trick! Thanks for your help!!
    -Mike
