Import Data hangs
Hi,
I am using RapidMiner Studio 9.6 Educational Edition in Ubuntu 19.04 box. I am trying to Import Data (Load Data) in RapidMiner repository. The CSV file is having 6 attributes and around 1200 examples. The overall file size is 25kb. The process hangs so that I needed to kill the process to terminate RapidMiner. Any help will be much appreciated. Thanks.
Raj Kishore
1 - 5 of
51
hi @Kompiler can you please share your rapidminer-studio.log file?
Hi @sgenzer please find the rapidminer-studio.log file attached herewith.
hi @Kompiler ok yes your HTML5 renderer is failing:
My colleague @BalazsBarany recommends using Amazon Coretto with all Linux/Ubuntu installations. See this thread for a full discussion: https://community.rapidminer.com/discussion/56326.
Scott
SEVERE: HTML5 Browser offscreen engine crashed, restarting! java.lang.IllegalStateException: Engine OFFSCREEN crashed: (129) at com.rapidminer.extension.browser.BrowserFactory.lambda$init$1(BrowserFactory.java:130) at com.teamdev.jxbrowser.event.internal.ObservableHelper.lambda$notifyObservers$0(ObservableHelper.java:63) at java.util.concurrent.CopyOnWriteArrayList.forEach(CopyOnWriteArrayList.java:891) at java.util.concurrent.CopyOnWriteArraySet.forEach(CopyOnWriteArraySet.java:404) at com.teamdev.jxbrowser.event.internal.ObservableHelper.notifyObservers(ObservableHelper.java:61) at com.teamdev.jxbrowser.engine.internal.EngineImpl.awaitProcessTermination(EngineImpl.java:564) at com.teamdev.jxbrowser.engine.internal.EngineImpl.close(EngineImpl.java:529) at java.lang.Thread.run(Thread.java:748)
Scott
Hi @sgenzer,
Thanks for your response. It seems that the problem is fixed now. I did the following:
Imported the Corretto public key and then add the repository to the system list by using the following commands
wget -O- https://apt.corretto.aws/corretto.key | sudo apt-key add -
sudo add-apt-repository 'deb https://apt.corretto.aws stable main'
Installed Corretto 8 by running command
sudo apt-get update; sudo apt-get install -y java-1.8.0-amazon-corretto-jdk
Ran the following command to verify the installation
java -version
Set the JAVA_HOME in /etc/environment
Also, I would like share with @BalazsBarany that this problem persists in RapidMiner Studio 9.6. Thanks.
Regards,
Raj
java -version
Regards,
Raj
Thanks @sgenzer for resolving the issue.
1 - 1 of
11
Hi @sgenzer,
java -version
Regards,
Raj
java -version
Regards,
Raj
