Determine optimal k using Silhouette index
Hi community,
can someone help me with regard to the question how the k-values of k-Means Clustering approach can be evaluated by using Silhouette index within RapidMiner?
Are there other alternatives to effectively evaluate the k-value beside the x-Means operator in RapidMiner? What would you recommend?
Thank you in advance!
Best regards!
Best regards!
1 - 4 of
41
Hi @lionelderkrikor,
thank you for your hint on the other thread!
Hi @sgenzer, there is no double-posting. This thread targets the calculation of the Silhouette index. Hence, the general question if a possibility exist within RapidMiner to calculate Silhouette? I did not get an answer to my question yet.
My research showed that there was a plugin from: http://korek.name/web/moje-tvorba/rapidminer-clustering_performance_plugin-average_silhouette-cophenetic_coefficient
But it seems like the link doesn't work anymore. Do you see alternatives for the problem?
Regards!
Regards!
@Muhammed_Fatih_
Hello
There is a lot of threads about "silhouette" in community if you search it you can find a lot of information for that
like this one
https://community.rapidminer.com/discussion/46239/how-to-calculate-silhouette-validation-for-k-means-using-r-in-rapidminer
Best regards
mbs
Hello
like this one
Best regards
mbs
See the answer in your other thread :
https://community.rapidminer.com/discussion/53024/error-on-determine-silhouette-for-k-means-clustering#latest
Regards,
Lionel
