With high dimensional data, it can be hard to know what the "best" number of clusters is and visual inspection of the data usually does not work. Unless you have an a priori preference for a specific number, you often will look for the tradeoffs between adding additional clusters and the marginal improvement in some global fitness metric (like the DB index), which is often referred to as the "elbow method" of cluster selection, as described here: https://en.wikipedia.org/wiki/Elbow_method_(clustering)
Based on that logic, I would probably select k=7 from your results, since the benefit of adding additional clusters is minimal (and thus there is a significant inflection point and change in slope at that point in the graph).
Hi @shiva1,
To estimate the right number of k, we can use the Bayesian Information Criterion (BIC).
I have tested an algorithm based on this criterion on the well known dataset "Iris" which contains 3 class :
The algorithms conclude that the right number of clusters was 3, so I think it can be relevant.
So I propose to you, to share your dataset in order to execute this algorithm on your dataset
to have more information.
Regards and happy new year 2018 !
Lionel
thanks
but i have text data and dbscan is not a good choice for text mining...cause it usually turn only one cluster
"clustering algorithm that produces a collection of clusters with the smallest Davies–Bouldin index is considered the best algorithm" -Wikipedia.
The Davies-Bouldin Index evaluates intra-cluster similarity and inter-cluster differences. If you consider these to be good criteria, go for the Davies-Bouldin.
My attached process is an optimization to pick the best K for K-means model, which returns k=3 has the lowest D-B index. You can also try X-mean to get an optimized clustering.
The D-B index was multiplied by -1 internally for maximizing it. You could ignore the negative sign from the performance output.
<?xml version="1.0" encoding="UTF-8"?><process version="8.2.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process">
<parameter key="notification_email" value="yhuang@rapidminer.com"/>
<parameter key="process_duration_for_mail" value="1"/>
<parameter key="encoding" value="UTF-8"/>
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="8.2.001" expanded="true" height="68" name="Ripley-Set" width="90" x="45" y="34">
<parameter key="repository_entry" value="//Samples/data/Ripley-Set"/>
</operator>
<operator activated="true" class="multiply" compatibility="8.2.001" expanded="true" height="103" name="Multiply" width="90" x="279" y="34"/>
<operator activated="true" class="concurrency:optimize_parameters_grid" compatibility="8.2.000" expanded="true" height="145" name="Optimize Parameters" width="90" x="514" y="34">
<list key="parameters">
<parameter key="Clustering.k" value="[2.0;20;19;linear]"/>
</list>
<operator activated="true" class="fast_k_means" compatibility="8.2.001" expanded="true" height="82" name="Clustering" width="90" x="246" y="34"/>
<operator activated="true" class="cluster_distance_performance" compatibility="8.2.001" expanded="true" height="103" name="Performance" width="90" x="648" y="34">
<parameter key="main_criterion" value="Davies Bouldin"/>
<parameter key="main_criterion_only" value="true"/>
</operator>
<connect from_port="input 1" to_op="Clustering" to_port="example set"/>
<connect from_op="Clustering" from_port="cluster model" to_op="Performance" to_port="cluster model"/>
<connect from_op="Clustering" from_port="clustered set" to_op="Performance" to_port="example set"/>
<connect from_op="Performance" from_port="performance" to_port="performance"/>
<connect from_op="Performance" from_port="example set" to_port="output 1"/>
<connect from_op="Performance" from_port="cluster model" to_port="model"/>
<portSpacing port="source_input 2" spacing="0"/>
<portSpacing port="sink_performance" spacing="0"/>
<portSpacing port="sink_model" spacing="0"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
<description align="left" color="green" colored="true" height="173" resized="false" width="626" x="109" y="164">Davies-Bouldin Index evaluates intra-cluster similarity and inter-cluster differences. If you consider these to be good criteria, go for the Davies-Bouldin. The Silhouette Index measure the distance between each data point, the centroid of the cluster it was assigned to and the closest centroid belonging to another cluster. If you consider that this is a good criterion, go for the silhouette index.<br><br>How can we say that a clustering quality measure is good?. Available from: https://www.researchgate.net/post/How_can_we_say_that_a_clustering_quality_measure_is_good.</description>
</process>
<description align="center" color="transparent" colored="false" width="126">figure out the best k for k-means</description>
</operator>
<operator activated="true" class="x_means" compatibility="8.2.001" expanded="true" height="82" name="X-Means" width="90" x="514" y="289">
<parameter key="k_max" value="10"/>
<description align="center" color="transparent" colored="false" width="126">run x-means for an optimzied clustering</description>
</operator>
<connect from_op="Ripley-Set" from_port="output" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="Optimize Parameters" to_port="input 1"/>
<connect from_op="Multiply" from_port="output 2" to_op="X-Means" to_port="example set"/>
<connect from_op="Optimize Parameters" from_port="parameter set" to_port="result 1"/>
<connect from_op="Optimize Parameters" from_port="output 1" to_port="result 2"/>
<connect from_op="X-Means" from_port="clustered set" to_port="result 3"/>
<portSpacing port="sink_result 1" spacing="42"/>
<portSpacing port="sink_result 3" spacing="189"/>
<portSpacing port="sink_result 4" spacing="0"/>
</process>
</operator>
</process>
Hi @shiva1,
Maybe a first step, is to perform an Exploratory Data Analysis to determine visually how many cluster there are. (you
go to the Charts panels and you can represent graphically your data.
A second approach is to use the DBSCAN operator (an other clustering method) who does not need
to have the number of cluster k as entry parameter.
I hope this first response elements will be useful.
Regards,
Lionel
