Connect Mysql Database via ODBC connector
User: "Gopal_Desai"
New Altair Community Member
Updated by Jocelyn
Hello everyone,
i am new here and i would like to connect mysql database with rapidminer via ODBC. but it doesn't show me ODBC Bridge option. If anyone know, please help me out.
1 - 3 of 31
    User: "BalazsBaranyRM"
    Accepted Answer
    Hi,
    do you have a very good reason to connect via ODBC?
    The JDBC-ODBC bridge has been deprecated for years. It is much less reliable and efficient than a direct JDBC connection.
    You should connect to MySQL with the MySQL or the MariaDB JDBC driver.
    Regards,
    Balázs
    User: "Gopal_Desai"
    OP
    Hi,
    Thank you for the Reply. I am using also another application with ODBC. So for me it's easy to connect Rapidminer with my Database.
    Regards,
    Gopal
    User: "Marco_Boeck"
    Altair Employee
    Accepted Answer
    Hi,
    I'm afraid ODBC is not supported, for reasons outlined above. You will have to use JDBC.
    Regards,
    Marco
